Hi guys,
I've got a minor problem with the view disks screen - one of them is missing the serial number. I checked with the camcontrol identify and it is showing there, as well as smartctl -i.
I believe this has to do with switching from the onboard SATA ports on a ASRock C2750D4I to a M1015 card (Marvell ports seemed dodgy). Before that the USB stick identified as da0 but now it's showing as da8 - da0 is the one missing the serial number in the web interface. I checked the freenas-v1.db sqlite3 database and that seems out of sync. (found command at https://bugs.freenas.org/issues/860)
Also that suggested exporting and using the auto-import which did not fix the database being out of sync with reality. Is there a quick & easy way I can fix this? Do I need to manually delete the da0 record from the database after doing the export before I auto-import?
Thanks!
Brandon
Thanks!
Brandon
