SMB Time Machine on 12.0-BETA
pitbullb
It took me days to get it working again after updating from 11.3.
My config looks like ChrisChros one.
To speed up the TimeMachine backup (at least the first backup) I disable the throttling of TM on the Mac:
sudo sysctl debug.lowpri_throttle_enabled=0
andrema2
What I'm seeing is TMs BKPs failing from time to time. Looks like the share is not found anymore. I have to stop and restart the service.
I haven't done any change on the parameters as you seem to be done.
Hi, I'm still seeing this behaviour. I didn't see any errors on the SMB service, other shares seems to be ok using SMB.
Looks like the mDNS is not properly advertising it.
anodos
Sambassador
What's output of following commands:
midclt call smb.config | jq
midclt call sharing.smb.query | jq
testparm -s
andrema2
testparm -s
@anodos , here it is following the commands above
  "id": 1,
  "netbiosname": "freenas",
  "netbiosname_b": "truenas-b",
  "netbiosalias": [
    "freenas"
  "workgroup": "WORKGROUP",
  "description": "FreeNAS Server",
  "unixcharset": "UTF-8",
  "loglevel": "MINIMUM",
  "syslog": false,
  "aapl_extensions": true,
  "localmaster": true,
  "guest": "nobody",
  "filemask": "",
  "dirmask": "",
  "smb_options": "strict sync = No",
  "bindip": [
    "10.2.2.2"
  "cifs_SID": "S-1-5-21-4212168799-811064797-3220049273",
  "ntlmv1_auth": false,
  "enable_smb1": false,
  "admin_group": null,
  "next_rid": 1008,
  "netbiosname_local": "freenas"
    "id": 2,
    "purpose": "ENHANCED_TIMEMACHINE",
    "path": "/mnt/TM",
    "path_suffix": "%U",
    "home": false,
    "name": "TMSMB",
    "comment": "",
    "ro": false,
    "browsable": true,
    "recyclebin": false,
    "guestok": false,
    "hostsallow": [],
    "hostsdeny": [],
    "auxsmbconf": "vfs objects = aio_fbsd tmprotect fruit streams_xattr shadow_copy_zfs ixnas",
    "aapl_name_mangling": false,
    "abe": false,
    "acl": true,
    "durablehandle": true,
    "streams": true,
    "timemachine": true,
    "vuid": "7fe675d1-d247-464e-91b0-925bb11b5d00",
    "shadowcopy": false,
    "fsrvp": false,
    "enabled": true
    "id": 3,
    "purpose": "DEFAULT_SHARE",
    "path": "/mnt/NAS",
    "path_suffix": "",
    "home": false,
    "name": "NAS",
    "comment": "",
    "ro": false,
    "browsable": true,
    "guestok": false,
    "hostsallow": [],
    "hostsdeny": [],
    "auxsmbconf": "",
    "abe": false,
    "acl": true,
    "streams": true,
    "timemachine": false,
    "vuid": "",
    "shadowcopy": true,
    "fsrvp": false,
    "enabled": true
Load smb config files from /usr/local/etc/smb4.conf
Loaded services file OK.
Server role: ROLE_STANDALONE
# Global parameters
[global]
    aio max threads = 2
    bind interfaces only = Yes
    disable spoolss = Yes
    dns proxy = No
    enable web service discovery = Yes
    interfaces = 127.0.0.1 10.2.2.2
    kernel change notify = No
    load printers = No
    logging = file
    max log size = 51200
    netbios aliases = freenas
    registry shares = Yes
    restrict anonymous = 2
    server role = standalone server
    unix extensions = No
    fruit:nfs_aces = No
    idmap config * : backend = tdb
    directory name cache size = 0
    dos filemode = Yes
    strict sync = No
[TMSMB]
    ea support = No
    kernel share modes = No
    path = /mnt/TM/%U
    posix locking = No
    read only = No
    fruit:resource = stream
    fruit:metadata = stream
    fruit:time machine = yes
    nfs4:chown = true
[NAS]
    ea support = No
    path = /mnt/NAS
    posix locking = No
    read only = No
    vfs objects = aio_fbsd fruit streams_xattr shadow_copy_zfs ixnas
    nfs4:chown = true
anodos
Sambassador
  "id": 1,
  "netbiosalias": [
    "freenas"
  "syslog": false,
  "guest": "nobody",
  "filemask": "",
  "dirmask": "",
  "bindip": [
    "10.2.2.2"
  "next_rid": 1008,
    "id": 2,
    "path": "/mnt/TM",
    "home": false,
    "name": "TMSMB",
    "comment": "",
    "ro": false,
    "browsable": true,
    "guestok": false,
    "hostsallow": [],
    "hostsdeny": [],
    "abe": false,
    "acl": true,
    "streams": true,
    "fsrvp": false,
    "enabled": true
    "id": 3,
    "path": "/mnt/NAS",
    "path_suffix": "",
    "home": false,
    "name": "NAS",
    "comment": "",
    "ro": false,
    "browsable": true,
    "guestok": false,
    "hostsallow": [],
    "hostsdeny": [],
    "auxsmbconf": "",
    "abe": false,
    "acl": true,
    "streams": true,
    "vuid": "",
    "shadowcopy": true,
    "fsrvp": false,
    "enabled": true
# Global parameters
[global]
    aio max threads = 2
    dns proxy = No
    load printers = No
    logging = file
    fruit:nfs_aces = No
    dos filemode = Yes
    strict sync = No
[TMSMB]
    ea support = No
    path = /mnt/TM/%U
    posix locking = No
    read only = No
    nfs4:chown = true
[NAS]
    ea support = No
    path = /mnt/NAS
    posix locking = No
    read only = No
    nfs4:chown = true
From your macos client, run command dns-sd -B _adisk._tcp. Is your server visible?
andrema2
Now it is.
I have restarted the server and it started working again.
I'll wait next time and run the commands again.
I'll post the results here.
anodos
Sambassador
Now it is.
Is FreeNAS virtualized or on physical hardware? Any log messages in /var/log/messages that correspond to the service becoming unavailable?
GBaughma
I'm getting:
The network backup disk does not support the required capabilities.
when I try to use time machine to back up to my SMB share that was working fine on 11.3U3.2.
What piece(s) am I missing?
freenas# testparm -s
# Global parameters
[global]
aio max threads = 2
dns proxy = No
interfaces = 127.0.0.1 192.168.200.2 2600:1700:210:b180:230:48ff:fecf:2b1c
load printers = No
logging = file
fruit:nfs_aces = No
dos filemode = Yes
[smb-tm]
ea support = No
path = /mnt/data/smb-tm
read only = No
vfs objects = zfs_space zfsacl streams_xattr
nfs4:chown = true
freenas# smbstatus -b
Samba version 4.12.3
PID Username Group Machine Protocol Version Encryption Signing
3800 ler ler 2600:1700:210:b180:c14a:dd5f:ad59:7491 (ipv6:2600:1700:210:b180:c14a:dd5f:ad59:7491:55856) SMB3_02 - partial(AES-128-CMAC)
freenas#
I was having this issue, and checking "Export recycle bin" seems to have resolved it.
majorgear
That worked for me as well. Your post saved my life...or at least it saved my TM backups as I'm migrating them from Synology to TrueNAS Scale v22.
