i am getting this alert,
is it somethig i should worry about
Gone alerts: * Unable to run alert source 'smartd' Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute return self.cursor.execute(sql, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 412, in execute execute = self.locked_retry(Database.Cursor.execute, query, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 403, in locked_retry raise e File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 389, in locked_retry rv = method(self, *args, **kwargs) sqlite3.OperationalError: database is locked The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/alert.py", line 358, in __run_source alerts = (await alert_source.check()) or [] File "/usr/local/lib/python3.6/site-packages/middlewared/alert/base.py", line 96, in check return await self.middleware.run_in_thread(self.check_sync) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1009, in run_in_thread return await self.loop.run_in_executor(executor, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/../alert/source/smartd.py", line 12, in check_sync ("srv_enable", "=", True)]): File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1139, in call_sync return fut.result() File "/usr/local/lib/python3.6/concurrent/futures/_base.py", line 425, in result return self.__get_result() File "/usr/local/lib/python3.6/concurrent/futures/_base.py", line 384, in __get_result raise self._exception File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1063, in _call return await run_method(methodobj, *args) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1009, in run_in_thread return await self.loop.run_in_executor(executor, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/datastore.py", line 175, in query select=options.get('select'), File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/datastore.py", line 88, in __queryset_serialize for i in qs: File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 256, in __iter__ self._fetch_all() File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 1087, in _fetch_all self._result_cache = list(self.iterator()) File "/usr/local/lib/python3.6/site-packages/django/db/models/query.py", line 54, in __iter__ results = compiler.execute_sql() File "/usr/local/lib/python3.6/site-packages/django/db/models/sql/compiler.py", line 835, in execute_sql cursor.execute(sql, params) File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute return self.cursor.execute(sql, params) File "/usr/local/lib/python3.6/site-packages/django/db/utils.py", line 94, in __exit__ six.reraise(dj_exc_type, dj_exc_value, traceback) File "/usr/local/lib/python3.6/site-packages/django/utils/six.py", line 685, in reraise raise value.with_traceback(tb) File "/usr/local/lib/python3.6/site-packages/django/db/backends/utils.py", line 64, in execute return self.cursor.execute(sql, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 412, in execute execute = self.locked_retry(Database.Cursor.execute, query, params) File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 403, in locked_retry raise e File "/usr/local/www/freenasUI/freeadmin/sqlite3_ha/base.py", line 389, in locked_retry rv = method(self, *args, **kwargs) django.db.utils.OperationalError: database is locked
