TheSmoker
- Sep 19, 2012
Hello FreeNAS lovers,
For quite some time I have a huge issue and I cannot for the world to fix it and that is the 1Gbps speed with 10Gbps network infrastructure.
I am running FreeNAS-11.2-U7 on the following hardware:
Supermicro X11SSH-CTF
Intel(R) Xeon(R) CPU E3-1270 v6
64GB ECC RAM
Based on the SM specs the Intel networking is powered by an Intel X550 chip.
My switch was an UBNT UniFi Switch 16 XG and now that has been replaced by an UBNT UniFi Switch 6 XG PoE.
Tried multiple network UTP/STP/SFTP cables, now running 2 Panduit CAT6A 2m cables to the switch.
The result is that it will not negotiate 10Gbps link.
On the older UniFi 16 XG it would negotiate 10G for a while and then would fall back to 1Gbps. If I would force 10Gbps on the switch, after a while it would disable the link.
I mention the fact that my desktop Aquantia AQN-107 10Gbps network adapter works without any issues on both switches.
Does anybody has any ideas how to go around this issue?
Thanks in advance for any feedback and/or advice!
Cheers!
64GB ECC RAM
Cheers!
root@jukebox:~ # lspci -v
09:00.0 Ethernet controller: Intel Corporation Ethernet Controller 10G X550T (rev 01)
Subsystem: Super Micro Computer Inc Device 1563
pcilib: 0000:09:00.0 64-bit device address ignored.
Flags: bus master, fast devsel, latency 0, IRQ 255
Memory at <ignored> (64-bit, prefetchable)
Expansion ROM at df180000 [disabled]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] MSI-X: Enable+ Count=64 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Device Serial Number 00-00-c9-ff-ff-00-00-00
Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
Capabilities: [160] Single Root I/O Virtualization (SR-IOV)
Capabilities: [1a0] Transaction Processing Hints
Capabilities: [1b0] Access Control Services
Capabilities: [1c0] Latency Tolerance Reporting
Capabilities: [1d0] #19
root@jukebox:~ # ifconfig -a
ix0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: connected to Birou8PoE (0/7)
options=a400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6>
ether 0c:c4:7a:c9:ab:e2
hwaddr 0c:c4:7a:c9:ab:e2
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
ix1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: connected to Birou8PoE (0/8)
hwaddr 0c:c4:7a:c9:ab:e3
status: active
root@jukebox:/boot/kernel # sysctl -a|grep ix kern.posix1version: 200112 kern.features.posix_shm: 1 kern.features.posix_sem: 1 kern.features.kposix_priority_scheduling: 1 device ix device ixv device ixl device ixlv net.inet.ip.no_same_prefix: 0 net.inet6.icmp6.nodeinfo_oldmcprefix: 1 hw.hn.udpcs_fixup_mtu: 1420 hw.hn.udpcs_fixup: 0 hw.ixlv.tx_itr: 122 hw.ixlv.rx_itr: 62 hw.ixlv.dynamic_tx_itr: 0 hw.ixlv.dynamic_rx_itr: 0 hw.ixlv.enable_head_writeback: 0 hw.ixlv.txbr_size: 4096 hw.ixlv.max_queues: 0 hw.ixlv.rx_ring_size: 1024 hw.ixlv.tx_ring_size: 1024 hw.ixl.tx_itr: 122 hw.ixl.rx_itr: 62 hw.ixl.dynamic_tx_itr: 1 hw.ixl.dynamic_rx_itr: 1 hw.ixl.shared_debug_mask: 0 hw.ixl.core_debug_mask: 0 hw.ixl.enable_head_writeback: 1 hw.ixl.enable_tx_fc_filter: 1 hw.ixl.max_queues: 0 hw.ixl.rx_ring_size: 1024 hw.ixl.tx_ring_size: 1024 hw.ixl.enable_msix: 1 hw.pci.msix_rewrite_table: 0 hw.pci.enable_msix: 1 hw.ix.enable_rss: 1 hw.ix.enable_legacy_tx: 0 hw.ix.enable_fdir: 0 hw.ix.unsupported_sfp: 0 hw.ix.rxd: 2048 hw.ix.txd: 2048 hw.ix.num_queues: 8 hw.ix.enable_msix: 1 hw.ix.advertise_speed: 0 hw.ix.flow_control: 3 hw.ix.tx_process_limit: 256 hw.ix.rx_process_limit: 256 hw.ix.max_interrupt_rate: 31250 hw.ix.enable_aim: 1 hw.igb.enable_msix: 1 hw.em.enable_msix: 1 machdep.disable_msix_migration: 0 user.posix2_version: 199212 user.posix2_c_bind: 0 user.posix2_c_dev: 0 user.posix2_char_term: 0 user.posix2_fort_dev: 0 user.posix2_fort_run: 0 user.posix2_localedef: 0 user.posix2_sw_dev: 0 user.posix2_upe: 0 dev.ix.1.mac_stats.tx_frames_1024_1522: 2284923 dev.ix.1.mac_stats.tx_frames_512_1023: 6669 dev.ix.1.mac_stats.tx_frames_256_511: 84090 dev.ix.1.mac_stats.tx_frames_128_255: 192533 dev.ix.1.mac_stats.tx_frames_65_127: 198284 dev.ix.1.mac_stats.tx_frames_64: 43426827 dev.ix.1.mac_stats.management_pkts_txd: 0 dev.ix.1.mac_stats.mcast_pkts_txd: 22181 dev.ix.1.mac_stats.bcast_pkts_txd: 19094 dev.ix.1.mac_stats.good_pkts_txd: 46193326 dev.ix.1.mac_stats.total_pkts_txd: 46193326 dev.ix.1.mac_stats.good_octets_txd: 6293182630 dev.ix.1.mac_stats.checksum_errs: 0 dev.ix.1.mac_stats.management_pkts_drpd: 0 dev.ix.1.mac_stats.management_pkts_rcvd: 0 dev.ix.1.mac_stats.recv_jabberd: 0 dev.ix.1.mac_stats.recv_oversized: 0 dev.ix.1.mac_stats.recv_fragmented: 0 dev.ix.1.mac_stats.recv_undersized: 0 dev.ix.1.mac_stats.rx_frames_1024_1522: 112456 dev.ix.1.mac_stats.rx_frames_512_1023: 26980 dev.ix.1.mac_stats.rx_frames_256_511: 235535 dev.ix.1.mac_stats.rx_frames_128_255: 186327 dev.ix.1.mac_stats.rx_frames_65_127: 445910 dev.ix.1.mac_stats.rx_frames_64: 790695 dev.ix.1.mac_stats.bcast_pkts_rcvd: 115476 dev.ix.1.mac_stats.mcast_pkts_rcvd: 143825 dev.ix.1.mac_stats.good_pkts_rcvd: 1797903 dev.ix.1.mac_stats.total_pkts_rcvd: 1797918 dev.ix.1.mac_stats.good_octets_rcvd: 390751199 dev.ix.1.mac_stats.total_octets_rcvd: 390753058 dev.ix.1.mac_stats.xoff_recvd: 0 dev.ix.1.mac_stats.xoff_txd: 0 dev.ix.1.mac_stats.xon_recvd: 0 dev.ix.1.mac_stats.xon_txd: 0 dev.ix.1.mac_stats.rx_missed_packets: 0 dev.ix.1.mac_stats.rec_len_errs: 0 dev.ix.1.mac_stats.remote_faults: 0 dev.ix.1.mac_stats.local_faults: 4 dev.ix.1.mac_stats.short_discards: 0 dev.ix.1.mac_stats.byte_errs: 0 dev.ix.1.mac_stats.ill_errs: 0 dev.ix.1.mac_stats.crc_errs: 0 dev.ix.1.queue7.lro_flushed: 0 dev.ix.1.queue7.lro_queued: 0 dev.ix.1.queue7.rx_discarded: 0 dev.ix.1.queue7.rx_copies: 206699 dev.ix.1.queue7.rx_bytes: 29356762 dev.ix.1.queue7.rx_packets: 238375 dev.ix.1.queue7.rxd_tail: 802 dev.ix.1.queue7.rxd_head: 803 dev.ix.1.queue7.br_drops: 0 dev.ix.1.queue7.tx_packets: 740946 dev.ix.1.queue7.no_desc_avail: 0 dev.ix.1.queue7.no_tx_dma_setup: 0 dev.ix.1.queue7.tso_tx: 0 dev.ix.1.queue7.txd_tail: 994 dev.ix.1.queue7.txd_head: 995 dev.ix.1.queue7.irqs: 391513 dev.ix.1.queue7.interrupt_rate: 50000 dev.ix.1.queue6.lro_flushed: 0 dev.ix.1.queue6.lro_queued: 0 dev.ix.1.queue6.rx_discarded: 0 dev.ix.1.queue6.rx_copies: 190555 dev.ix.1.queue6.rx_bytes: 152750515 dev.ix.1.queue6.rx_packets: 320969 dev.ix.1.queue6.rxd_tail: 1480 dev.ix.1.queue6.rxd_head: 1481 dev.ix.1.queue6.br_drops: 0 dev.ix.1.queue6.tx_packets: 431298 dev.ix.1.queue6.no_desc_avail: 0 dev.ix.1.queue6.no_tx_dma_setup: 0 dev.ix.1.queue6.tso_tx: 0 dev.ix.1.queue6.txd_tail: 52 dev.ix.1.queue6.txd_head: 52 dev.ix.1.queue6.irqs: 343014 dev.ix.1.queue6.interrupt_rate: 11363 dev.ix.1.queue5.lro_flushed: 0 dev.ix.1.queue5.lro_queued: 0 dev.ix.1.queue5.rx_discarded: 0 dev.ix.1.queue5.rx_copies: 110168 dev.ix.1.queue5.rx_bytes: 32116954 dev.ix.1.queue5.rx_packets: 158383 dev.ix.1.queue5.rxd_tail: 684 dev.ix.1.queue5.rxd_head: 685 dev.ix.1.queue5.br_drops: 0 dev.ix.1.queue5.tx_packets: 346967 dev.ix.1.queue5.no_desc_avail: 0 dev.ix.1.queue5.no_tx_dma_setup: 0 dev.ix.1.queue5.tso_tx: 0 dev.ix.1.queue5.txd_tail: 516 dev.ix.1.queue5.txd_head: 516 dev.ix.1.queue5.irqs: 173751 dev.ix.1.queue5.interrupt_rate: 500000 dev.ix.1.queue4.lro_flushed: 0 dev.ix.1.queue4.lro_queued: 0 dev.ix.1.queue4.rx_discarded: 0 dev.ix.1.queue4.rx_copies: 160307 dev.ix.1.queue4.rx_bytes: 59004851 dev.ix.1.queue4.rx_packets: 256758 dev.ix.1.queue4.rxd_tail: 755 dev.ix.1.queue4.rxd_head: 756 dev.ix.1.queue4.br_drops: 0 dev.ix.1.queue4.tx_packets: 148219 dev.ix.1.queue4.no_desc_avail: 0 dev.ix.1.queue4.no_tx_dma_setup: 0 dev.ix.1.queue4.tso_tx: 0 dev.ix.1.queue4.txd_tail: 376 dev.ix.1.queue4.txd_head: 376 dev.ix.1.queue4.irqs: 292917 dev.ix.1.queue4.interrupt_rate: 500000 dev.ix.1.queue3.lro_flushed: 0 dev.ix.1.queue3.lro_queued: 0 dev.ix.1.queue3.rx_discarded: 0 dev.ix.1.queue3.rx_copies: 91019 dev.ix.1.queue3.rx_bytes: 26425444 dev.ix.1.queue3.rx_packets: 127165 dev.ix.1.queue3.rxd_tail: 188 dev.ix.1.queue3.rxd_head: 189 dev.ix.1.queue3.br_drops: 0 dev.ix.1.queue3.tx_packets: 41499672 dev.ix.1.queue3.no_desc_avail: 0 dev.ix.1.queue3.no_tx_dma_setup: 0 dev.ix.1.queue3.tso_tx: 0 dev.ix.1.queue3.txd_tail: 530 dev.ix.1.queue3.txd_head: 530 dev.ix.1.queue3.irqs: 41457636 dev.ix.1.queue3.interrupt_rate: 31250 dev.ix.1.queue2.lro_flushed: 0 dev.ix.1.queue2.lro_queued: 0 dev.ix.1.queue2.rx_discarded: 0 dev.ix.1.queue2.rx_copies: 280334 dev.ix.1.queue2.rx_bytes: 27647859 dev.ix.1.queue2.rx_packets: 290419 dev.ix.1.queue2.rxd_tail: 1648 dev.ix.1.queue2.rxd_head: 1649 dev.ix.1.queue2.br_drops: 0 dev.ix.1.queue2.tx_packets: 72034 dev.ix.1.queue2.no_desc_avail: 0 dev.ix.1.queue2.no_tx_dma_setup: 0 dev.ix.1.queue2.tso_tx: 0 dev.ix.1.queue2.txd_tail: 1544 dev.ix.1.queue2.txd_head: 1544 dev.ix.1.queue2.irqs: 361433 dev.ix.1.queue2.interrupt_rate: 500000 dev.ix.1.queue1.lro_flushed: 0 dev.ix.1.queue1.lro_queued: 0 dev.ix.1.queue1.rx_discarded: 0 dev.ix.1.queue1.rx_copies: 162013 dev.ix.1.queue1.rx_bytes: 33650902 dev.ix.1.queue1.rx_packets: 206013 dev.ix.1.queue1.rxd_tail: 1209 dev.ix.1.queue1.rxd_head: 1210 dev.ix.1.queue1.br_drops: 0 dev.ix.1.queue1.tx_packets: 2735949 dev.ix.1.queue1.no_desc_avail: 6849 dev.ix.1.queue1.no_tx_dma_setup: 0 dev.ix.1.queue1.tso_tx: 0 dev.ix.1.queue1.txd_tail: 1773 dev.ix.1.queue1.txd_head: 1773 dev.ix.1.queue1.irqs: 2400519 dev.ix.1.queue1.interrupt_rate: 500000 dev.ix.1.queue0.lro_flushed: 0 dev.ix.1.queue0.lro_queued: 0 dev.ix.1.queue0.rx_discarded: 0 dev.ix.1.queue0.rx_copies: 185499 dev.ix.1.queue0.rx_bytes: 22602700 dev.ix.1.queue0.rx_packets: 199823 dev.ix.1.queue0.rxd_tail: 1141 dev.ix.1.queue0.rxd_head: 1142 dev.ix.1.queue0.br_drops: 0 dev.ix.1.queue0.tx_packets: 218343 dev.ix.1.queue0.no_desc_avail: 0 dev.ix.1.queue0.no_tx_dma_setup: 0 dev.ix.1.queue0.tso_tx: 0 dev.ix.1.queue0.txd_tail: 797 dev.ix.1.queue0.txd_head: 797 dev.ix.1.queue0.irqs: 209166 dev.ix.1.queue0.interrupt_rate: 500000 dev.ix.1.link_irq: 4 dev.ix.1.watchdog_events: 0 dev.ix.1.mbuf_defrag_failed: 0 dev.ix.1.dropped: 0 dev.ix.1.dmac: 0 dev.ix.1.advertise_speed: 7 dev.ix.1.enable_aim: 1 dev.ix.1.fc: 0 dev.ix.1.tx_processing_limit: 256 dev.ix.1.rx_processing_limit: 256 dev.ix.1.%parent: pci9 dev.ix.1.%pnpinfo: vendor=0x8086 device=0x1563 subvendor=0x15d9 subdevice=0x1563 class=0x020000 dev.ix.1.%location: slot=0 function=1 dbsf=pci0:9:0:1 dev.ix.1.%driver: ix dev.ix.1.%desc: Intel(R) PRO/10GbE PCI-Express Network Driver, Version - 3.2.12-k dev.ix.0.wake: 0 dev.ix.0.mac_stats.tx_frames_1024_1522: 2088449 dev.ix.0.mac_stats.tx_frames_512_1023: 9662 dev.ix.0.mac_stats.tx_frames_256_511: 97370 dev.ix.0.mac_stats.tx_frames_128_255: 137456 dev.ix.0.mac_stats.tx_frames_65_127: 180654 dev.ix.0.mac_stats.tx_frames_64: 2980251 dev.ix.0.mac_stats.management_pkts_txd: 0 dev.ix.0.mac_stats.mcast_pkts_txd: 6512 dev.ix.0.mac_stats.bcast_pkts_txd: 43117 dev.ix.0.mac_stats.good_pkts_txd: 5493842 dev.ix.0.mac_stats.total_pkts_txd: 5493842 dev.ix.0.mac_stats.good_octets_txd: 3418863723 dev.ix.0.mac_stats.checksum_errs: 0 dev.ix.0.mac_stats.management_pkts_drpd: 0 dev.ix.0.mac_stats.management_pkts_rcvd: 0 dev.ix.0.mac_stats.recv_jabberd: 0 dev.ix.0.mac_stats.recv_oversized: 0 dev.ix.0.mac_stats.recv_fragmented: 0 dev.ix.0.mac_stats.recv_undersized: 0 dev.ix.0.mac_stats.rx_frames_1024_1522: 92634671 dev.ix.0.mac_stats.rx_frames_512_1023: 27969 dev.ix.0.mac_stats.rx_frames_256_511: 48286 dev.ix.0.mac_stats.rx_frames_128_255: 123037 dev.ix.0.mac_stats.rx_frames_65_127: 79924 dev.ix.0.mac_stats.rx_frames_64: 161807 dev.ix.0.mac_stats.bcast_pkts_rcvd: 62151 dev.ix.0.mac_stats.mcast_pkts_rcvd: 125380 dev.ix.0.mac_stats.good_pkts_rcvd: 93075694 dev.ix.0.mac_stats.total_pkts_rcvd: 93075721 dev.ix.0.mac_stats.good_octets_rcvd: 140694947352 dev.ix.0.mac_stats.total_octets_rcvd: 140694950809 dev.ix.0.mac_stats.xoff_recvd: 0 dev.ix.0.mac_stats.xoff_txd: 0 dev.ix.0.mac_stats.xon_recvd: 0 dev.ix.0.mac_stats.xon_txd: 0 dev.ix.0.mac_stats.rx_missed_packets: 0 dev.ix.0.mac_stats.rec_len_errs: 0 dev.ix.0.mac_stats.remote_faults: 0 dev.ix.0.mac_stats.local_faults: 2 dev.ix.0.mac_stats.short_discards: 0 dev.ix.0.mac_stats.byte_errs: 0 dev.ix.0.mac_stats.ill_errs: 0 dev.ix.0.mac_stats.crc_errs: 0 dev.ix.0.queue7.lro_flushed: 5 dev.ix.0.queue7.lro_queued: 5 dev.ix.0.queue7.rx_discarded: 0 dev.ix.0.queue7.rx_copies: 27284 dev.ix.0.queue7.rx_bytes: 4191954069 dev.ix.0.queue7.rx_packets: 2817944 dev.ix.0.queue7.rxd_tail: 1929 dev.ix.0.queue7.rxd_head: 1930 dev.ix.0.queue7.br_drops: 0 dev.ix.0.queue7.tx_packets: 1695154 dev.ix.0.queue7.no_desc_avail: 0 dev.ix.0.queue7.no_tx_dma_setup: 0 dev.ix.0.queue7.tso_tx: 0 dev.ix.0.queue7.txd_tail: 102 dev.ix.0.queue7.txd_head: 102 dev.ix.0.queue7.irqs: 3442776 dev.ix.0.queue7.interrupt_rate: 500000 dev.ix.0.queue6.lro_flushed: 0 dev.ix.0.queue6.lro_queued: 0 dev.ix.0.queue6.rx_discarded: 0 dev.ix.0.queue6.rx_copies: 25536 dev.ix.0.queue6.rx_bytes: 24411766 dev.ix.0.queue6.rx_packets: 43896 dev.ix.0.queue6.rxd_tail: 882 dev.ix.0.queue6.rxd_head: 883 dev.ix.0.queue6.br_drops: 0 dev.ix.0.queue6.tx_packets: 244953 dev.ix.0.queue6.no_desc_avail: 0 dev.ix.0.queue6.no_tx_dma_setup: 0 dev.ix.0.queue6.tso_tx: 0 dev.ix.0.queue6.txd_tail: 842 dev.ix.0.queue6.txd_head: 842 dev.ix.0.queue6.irqs: 145346 dev.ix.0.queue6.interrupt_rate: 500000 dev.ix.0.queue5.lro_flushed: 2 dev.ix.0.queue5.lro_queued: 2 dev.ix.0.queue5.rx_discarded: 0 dev.ix.0.queue5.rx_copies: 8444 dev.ix.0.queue5.rx_bytes: 36078382 dev.ix.0.queue5.rx_packets: 77229 dev.ix.0.queue5.rxd_tail: 1439 dev.ix.0.queue5.rxd_head: 1440 dev.ix.0.queue5.br_drops: 0 dev.ix.0.queue5.tx_packets: 54615 dev.ix.0.queue5.no_desc_avail: 0 dev.ix.0.queue5.no_tx_dma_setup: 0 dev.ix.0.queue5.tso_tx: 0 dev.ix.0.queue5.txd_tail: 1051 dev.ix.0.queue5.txd_head: 1051 dev.ix.0.queue5.irqs: 123690 dev.ix.0.queue5.interrupt_rate: 100000 dev.ix.0.queue4.lro_flushed: 0 dev.ix.0.queue4.lro_queued: 0 dev.ix.0.queue4.rx_discarded: 0 dev.ix.0.queue4.rx_copies: 8641 dev.ix.0.queue4.rx_bytes: 7013186 dev.ix.0.queue4.rx_packets: 15076 dev.ix.0.queue4.rxd_tail: 736 dev.ix.0.queue4.rxd_head: 737 dev.ix.0.queue4.br_drops: 0 dev.ix.0.queue4.tx_packets: 469969 dev.ix.0.queue4.no_desc_avail: 0 dev.ix.0.queue4.no_tx_dma_setup: 0 dev.ix.0.queue4.tso_tx: 0 dev.ix.0.queue4.txd_tail: 1214 dev.ix.0.queue4.txd_head: 1214 dev.ix.0.queue4.irqs: 86465 dev.ix.0.queue4.interrupt_rate: 29411 dev.ix.0.queue3.lro_flushed: 0 dev.ix.0.queue3.lro_queued: 0 dev.ix.0.queue3.rx_discarded: 0 dev.ix.0.queue3.rx_copies: 43132 dev.ix.0.queue3.rx_bytes: 124743917026 dev.ix.0.queue3.rx_packets: 82455122 dev.ix.0.queue3.rxd_tail: 591 dev.ix.0.queue3.rxd_head: 592 dev.ix.0.queue3.br_drops: 0 dev.ix.0.queue3.tx_packets: 40699 dev.ix.0.queue3.no_desc_avail: 0 dev.ix.0.queue3.no_tx_dma_setup: 0 dev.ix.0.queue3.tso_tx: 0 dev.ix.0.queue3.txd_tail: 757 dev.ix.0.queue3.txd_head: 757 dev.ix.0.queue3.irqs: 82448192 dev.ix.0.queue3.interrupt_rate: 31250 dev.ix.0.queue2.lro_flushed: 8 dev.ix.0.queue2.lro_queued: 8 dev.ix.0.queue2.rx_discarded: 0 dev.ix.0.queue2.rx_copies: 7379 dev.ix.0.queue2.rx_bytes: 68242113 dev.ix.0.queue2.rx_packets: 52687 dev.ix.0.queue2.rxd_tail: 1473 dev.ix.0.queue2.rxd_head: 1474 dev.ix.0.queue2.br_drops: 0 dev.ix.0.queue2.tx_packets: 1225278 dev.ix.0.queue2.no_desc_avail: 0 dev.ix.0.queue2.no_tx_dma_setup: 0 dev.ix.0.queue2.tso_tx: 0 dev.ix.0.queue2.txd_tail: 1239 dev.ix.0.queue2.txd_head: 1239 dev.ix.0.queue2.irqs: 229375 dev.ix.0.queue2.interrupt_rate: 31250 dev.ix.0.queue1.lro_flushed: 0 dev.ix.0.queue1.lro_queued: 0 dev.ix.0.queue1.rx_discarded: 0 dev.ix.0.queue1.rx_copies: 19147 dev.ix.0.queue1.rx_bytes: 6619326411 dev.ix.0.queue1.rx_packets: 4392986 dev.ix.0.queue1.rxd_tail: 23 dev.ix.0.queue1.rxd_head: 24 dev.ix.0.queue1.br_drops: 0 dev.ix.0.queue1.tx_packets: 98419 dev.ix.0.queue1.no_desc_avail: 0 dev.ix.0.queue1.no_tx_dma_setup: 0 dev.ix.0.queue1.tso_tx: 0 dev.ix.0.queue1.txd_tail: 301 dev.ix.0.queue1.txd_head: 301 dev.ix.0.queue1.irqs: 4451027 dev.ix.0.queue1.interrupt_rate: 500000 dev.ix.0.queue0.lro_flushed: 0 dev.ix.0.queue0.lro_queued: 0 dev.ix.0.queue0.rx_discarded: 0 dev.ix.0.queue0.rx_copies: 128512 dev.ix.0.queue0.rx_bytes: 4631686473 dev.ix.0.queue0.rx_packets: 3220809 dev.ix.0.queue0.rxd_tail: 1253 dev.ix.0.queue0.rxd_head: 1254 dev.ix.0.queue0.br_drops: 0 dev.ix.0.queue0.tx_packets: 1664761 dev.ix.0.queue0.no_desc_avail: 0 dev.ix.0.queue0.no_tx_dma_setup: 0 dev.ix.0.queue0.tso_tx: 0 dev.ix.0.queue0.txd_tail: 1699 dev.ix.0.queue0.txd_head: 1699 dev.ix.0.queue0.irqs: 3904445 dev.ix.0.queue0.interrupt_rate: 500000 dev.ix.0.link_irq: 4 dev.ix.0.watchdog_events: 0 dev.ix.0.mbuf_defrag_failed: 0 dev.ix.0.dropped: 0 dev.ix.0.dmac: 0 dev.ix.0.advertise_speed: 7 dev.ix.0.enable_aim: 1 dev.ix.0.fc: 0 dev.ix.0.tx_processing_limit: 256 dev.ix.0.rx_processing_limit: 256 dev.ix.0.%parent: pci9 dev.ix.0.%pnpinfo: vendor=0x8086 device=0x1563 subvendor=0x15d9 subdevice=0x1563 class=0x020000 dev.ix.0.%location: slot=0 function=0 dbsf=pci0:9:0:0 handle=\_SB_.PCI0.RP05.PXSX dev.ix.0.%driver: ix dev.ix.0.%desc: Intel(R) PRO/10GbE PCI-Express Network Driver, Version - 3.2.12-k dev.ix.%parent: dev.mpr.0.disable_msix: 0
