read speed is slow
bones0008
My freenas is build on a DIY box with 64GB RAM, and AVAGO MR9361-8i RAID card (1G cache) with 24 hard drive RAID-6, space is 200TB. No cache drive and log drive. 10Gb Ethernet port.
Free nas version is 11.3-U5. Compression is off. Single volume.
I use dd command to test the read and write speed on it with 100GB file. Speed looks good.
write speed is 1825053492 bytes/sec
read speed is 1772204604 bytes/sec
(check the attachment)
But I use NFS share connect from my test box (with 10Gb Ethernet), CENTOS 7.7 NFS version 3
write speed is 1.08GB/s
read speed is 318MB/s
I don't know why the read speed is slow. Because the RAM is too small? Any one has idea about this?
SweetAndLow
Sweet'NASty
Start with iperf and test going both directions. Then do a dd test over the wire both directions. See what info that gives you.
I can see 2 problems here:
This is a bad card to be using. Have you created RAID6 across the 24 disks using the card's RAID? (https://www.truenas.com/community/t...s-and-why-cant-i-use-a-raid-controller.81931/)
Also, if you have correctly allowed FreeNAS to manage the RAID of the 24 disks (and presumably have a RAIDZ2 pool with a single VDEV), that's way wider than recommended for RAIDZ2 (usually 12 maximum).
bones0008
sorry for the late reply, quite busy.
that is the number I tested on client, the iperf connect speed is 9.86Gb/s.
bones0008
Thanks for your reply,
Yes, I created RAID6 across 24 disks under the RAID card.
I will try to use JOB mode on that card and try again.
SweetAndLow
Sweet'NASty
Jbod isn't enough. You need hba
