andrenel212
- Apr 29, 2017
I get the following error when trying to install any plugin:
Environment:
Software Version: FreeNAS-11.1-RELEASE (dc7d195f4)
Request Method: POST
Request URL: http://192.168.0.2/plugins/plugin/install/f9f9be875651fc5e830012bf3bc7067a9d1f31b3fce706eeb6cfcd7f3742f273/
Traceback:
File "./freenasUI/jails/utils.py" in new_default_plugin_jail
718. w.create(**create_args)
File "./freenasUI/common/warden.py" in create
1097. return self.__call(warden_create(flags, **kwargs))
File "./freenasUI/common/warden.py" in __call
1070. tmp = obj.run()
File "./freenasUI/common/warden.py" in run
465. raise warden_exception(msg)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner
42. response = get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response
249. response = self._get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response
178. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "./freenasUI/freeadmin/middleware.py" in process_view
162. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
23. return view_func(request, *args, **kwargs)
File "./freenasUI/plugins/views.py" in install_available
306. raise e
302. jail = new_default_plugin_jail(plugin.unixname)
721. raise MiddlewareError(_("Failed to install plugin: %s") % e)
Exception Type: MiddlewareError at /plugins/plugin/install/f9f9be875651fc5e830012bf3bc7067a9d1f31b3fce706eeb6cfcd7f3742f273/
Exception Value: [MiddlewareError: Failed to install plugin: [warden_exception: cannot open 'Drive/jails/.warden-template-pluginjail@clean': dataset does not exist
ERROR: Failed creating clean ZFS base clone
