SOLVED plex runtime error
PTmans
Hello, im having trouble setting up plex. Ive read a few forum posts with similar issues. Plex is failing to install with the following issue after ive set up my routers IP as the 1st DNS. Im not sure what to do, NAT and setting the ip manually also fail.
Hardware:
CPU: i3012100F
Mobo: ASRock H670M-ITX
Ram: Trident Z RGB 2x8 DDR4-3000 CL15
Drives: Boot, Kingston A400, Mirror pool, Segate EXOS 16TBx2 Vdev: Intel Optane Memory H10 1TB
Im using the onboard network port
PTmans
Edit: My truenas version is 12.0-U8.1. The plugin installed using NAT however im getting this error that was happening when i first installed it
If i change the jail settings to DHCP it says IPv4 DHCP (not running) with the following error codes on the plugin
Add the IP of your router in the field "IPv4 Default Gateway" in the Network > Global Configuration section.
PTmans
It's giving me the same errors, IPv4 error or DHCP not running when using DHCP and Berkely packet filter and VNET. and the managment portal wont load with NAT
