Hey all!
I made some changes to the way that Samba logs my users' activity, and want to use it for the default. Because it's a read only filesystem, I do the mount -uw / command, which looks like it works, then copy my file over, and then do the mount -ur / command, which also appears to work. I then verify that the file is correct, which it is.
I even copy the file over to the /conf..... folder structure and overwrite that file.
All is well across the board. HOWEVER, once I reboot, everything reverts to the way it was. Is there something I'm doing wrong? I'm running the latest FreeNAS. Thanks in advance everyone!
