Options for Degraded Zpool Raidz1-0 2 files corrupted
mysticpete
Hi Team
Can someone give me a hand with this one, shell is showing that two files in the pool have been corrupted, but not that its a drive related problem, rather the pool itself,.
here's my output
root@freenas:/ # zpool status
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:01:20 with 0 errors on Wed Sep 16 03:46:20 2020
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
ada5p2 ONLINE 0 0 0
errors: No known data errors
pool: media
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 0 in 0 days 04:13:54 with 2 errors on Sat Sep 19 16:20:59 2020
media DEGRADED 2 0 0
raidz1-0 DEGRADED 2 0 0
5447227299327320603 REMOVED 0 0 0 was /dev/gptid/c8198192-42f6-11e3-b481-c8cbb8c52f20
gptid/c8f8d91d-42f6-11e3-b481-c8cbb8c52f20 ONLINE 0 0 0
gptid/c98173f8-42f6-11e3-b481-c8cbb8c52f20 ONLINE 2 0 0
gptid/ca025a49-42f6-11e3-b481-c8cbb8c52f20 ONLINE 0 0 0
gptid/304c50d2-ff29-11e6-87ad-c8cbb8c52f20 ONLINE 0 0 0
errors: 2 data errors, use '-v' for a list
root@freenas:/ # zpool status -v
pool: freenas-boot
state: ONLINE
ada5p2 ONLINE 0 0 0
pool: media
state: DEGRADED
media/media/movies/movies_kids@auto-20200301.0100-2w:/Ice Age Continental Drift/Ice Age Continental Drift-1.m4v
media/media/software@auto-20200301.0100-2w:/HP_Backup/Users/Peter/Pictures/2014-05-04/MVI_0913.MOV
Can someone advise what are my options for repair?
Thanks in advance
Pete
Alecmascot
It seems that you have one drive missing from the array and another is giving read errors.
The array is at risk as it is RaidZ-1.
I suggest you replace the missing drive and when the resilver is finished you look at read errors.
Please post console cut/pastes in code tags to make them easier to read.
Since both of your errors are in snapshots and those snapshots should be expired by now according to the timestamps (March 1st 2020 with 2 week Expiry), you should just destroy those snapshots (and consider looking into the setup of the snapshot job as the automatic removal isn't working).
mysticpete
Thanks I have deleted the old ones, not sure why they are not auto deleting after the two weeks....
mysticpete
This is what I get when listing the zpool now, there are 4 2TB drives and an SSD with the freenas software on it.
root@freenas:/ # zpool status -xv
pool: media
state: DEGRADED
scan: scrub in progress since Sat Sep 19 18:47:51 2020
3.30T scanned at 456M/s, 2.56T issued at 354M/s, 4.02T total
0 repaired, 63.73% done, 0 days 01:11:58 to go
media DEGRADED 5 0 0
raidz1-0 DEGRADED 5 0 0
gptid/c98173f8-42f6-11e3-b481-c8cbb8c52f20 ONLINE 5 0 0
<0x1016>:<0x2cb>
<0x1020>:<0x3752>
This looks a bit more serious now, as you can see I'm doing a scrub right now.
mysticpete
Scrub finished,not good news.....
pool: media
state: DEGRADED
scan: scrub repaired 0 in 0 days 04:07:49 with 3 errors on Sat Sep 19 22:55:40 2020
<0x1016>:<0x2cb>
<0x1020>:<0x3752>
mysticpete
All fixed, rolled back with a snapshot cleaned all the old snapshots and restarted all good again.
