mjrose2003
 - Jan 21, 2019
New FreeNAS user. I have a new FreeNAS 11.2 installation that works fine when connecting with 1 Windows 7 PC and a Mac laptop. I also have a Windows 10 PC that will not let me connect to the FreeNAS drive. It just keeps giving me the login screen as if I am using the wrong username/password. I am using the same info I used on the other PC and the Mac. I can ping the FreeNAS box, the fact that I am getting the login box at all says I am connected. Both PCs are on the same workgroup. Tried deleting the credentials for that connection and re-entering. Network discovery is on. The Windows 7 PC is wired with Ethernet. The Windows 10 and Mac are wifi, if that matters. I can't think if anything else. Something about Windows 10??
