Panagiotis G
- Oct 14, 2016
First of all, congratulation to FreeNAS team for the great software.
This is my first attempt to run and install FreeNAS on production environment as a simple CIFS server joining in our Domain.
At first I have consider reading the how to over there : https://forums.freenas.org/index.ph...directory-folder-file-user-permissions.20610/ which helped me from a lot of trouble. Freenas has been installed on an ESXi 6 configured with 8GB ram and 2x10GB disk, one disk for installation and one for Raid 0 for simpe cifs shareing without compression. Now After a successfully domain join, strange things start happening. After reboot the server is no longer accessible. I can see a few bunch of logs line from the Dashboard as below :
After a Second restart, the logs it seems different again
Just to be sure I have apply also the latest update from FreeNAS and now the booting is somehow different, please check below :
At the moment if I type \\kalisto from a workstation the response is "The file cannot be accessed by the system."
Can someone help me in order to investigate and solve the issue?
Thank you
Oct 14 12:27:03 kalisto sc0: <System console> at flags 0x100 on isa0 Oct 14 12:27:03 kalisto sc0: VGA <16 virtual consoles, flags=0x300> Oct 14 12:27:03 kalisto vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0 Oct 14 12:27:03 kalisto coretemp0: <CPU On-Die Thermal Sensors> on cpu0 Oct 14 12:27:03 kalisto coretemp0: Tj(target) value 0 does not seem right. Oct 14 12:27:03 kalisto ZFS filesystem version: 5 Oct 14 12:27:03 kalisto ZFS storage pool version: features support (5000) Oct 14 12:27:03 kalisto Timecounters tick every 1.000 msec Oct 14 12:27:03 kalisto ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled Oct 14 12:27:03 kalisto random: unblocking device. Oct 14 12:27:03 kalisto da0 at mpt0 bus 0 scbus2 target 0 lun 0 Oct 14 12:27:03 kalisto da0: <VMware Virtual disk 1.0> Fixed Direct Access SCSI-2 device Oct 14 12:27:03 kalisto da0: 320.000MB/s transfers (160.000MHz DT, offset 127, 16bit) Oct 14 12:27:03 kalisto da0: Command Queueing enabled Oct 14 12:27:03 kalisto da0: 10240MB (20971520 512 byte sectors) Oct 14 12:27:03 kalisto da0: quirks=0x40<RETRY_BUSY> Oct 14 12:27:03 kalisto da1 at mpt0 bus 0 scbus2 target 1 lun 0 Oct 14 12:27:03 kalisto da1: <VMware Virtual disk 1.0> Fixed Direct Access SCSI-2 device Oct 14 12:27:03 kalisto da1: 320.000MB/s transfers (160.000MHz DT, offset 127, 16bit) Oct 14 12:27:03 kalisto da1: Command Queueing enabled Oct 14 12:27:03 kalisto da1: 10240MB (20971520 512 byte sectors) Oct 14 12:27:03 kalisto da1: quirks=0x40<RETRY_BUSY> Oct 14 12:27:03 kalisto cd0 at ata1 bus 0 scbus1 target 0 lun 0 Oct 14 12:27:03 kalisto cd0: <NECVMWar VMware IDE CDR10 1.00> Removable CD-ROM SCSI device Oct 14 12:27:03 kalisto cd0: Serial Number 10000000000000000001 Oct 14 12:27:03 kalisto cd0: 33.300MB/s transfers (UDMA2, ATAPI 12bytes, PIO 65534bytes) Oct 14 12:27:03 kalisto cd0: Attempt to query device size failed: NOT READY, Medium not present Oct 14 12:27:03 kalisto cd0: quirks=0x40<RETRY_BUSY> Oct 14 12:27:03 kalisto Timecounter "TSC-low" frequency 1197227500 Hz quality 1000 Oct 14 12:27:03 kalisto Trying to mount root from zfs:freenas-boot/ROOT/default []... Oct 14 12:27:03 kalisto GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7) Oct 14 12:27:03 kalisto hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/0/0/0x67<INT,USR,SYS,REA,WRI> Oct 14 12:27:03 kalisto VMware memory control driver initialized Oct 14 12:27:03 kalisto kernel: vmx0: link state changed to UP Oct 14 12:27:03 kalisto kernel: vmx0: link state changed to UP Oct 14 12:27:05 kalisto generate_krb5_conf.py: [common.pipesubr:66] Popen()ing: klist Oct 14 12:27:05 kalisto generate_krb5_conf.py: [common.pipesubr:66] Popen()ing: /usr/bin/kinit --renewable --password-file=/tmp/tmpQCqmle kalistoservice@[REMOVED FOR POSTING] Oct 14 12:27:05 kalisto root: /etc/rc: WARNING: failed to start watchdogd Oct 14 12:27:06 kalisto GEOM_ELI: Device da1p1.eli created. Oct 14 12:27:06 kalisto GEOM_ELI: Encryption: AES-XTS 128 Oct 14 12:27:06 kalisto GEOM_ELI: Crypto: hardware Oct 14 12:27:06 kalisto ntpd[2486]: ntpd 4.2.8p8-a (1): Starting Oct 14 12:15:33 kalisto generate_smb4_conf.py: [generate_smb4_conf:1498] Unable to open /var/db/samba4/private/secrets.tdb: [Errno 2] No such file or directory Oct 14 12:15:33 kalisto generate_smb4_conf.py: [common.pipesubr:66] Popen()ing: /sbin/sysctl -n 'kern.maxfilesperproc' Oct 14 12:15:33 kalisto generate_smb4_conf.py: [common.pipesubr:66] Popen()ing: klist Oct 14 12:15:33 kalisto generate_smb4_conf.py: [common.pipesubr:66] Popen()ing: mount Oct 14 12:15:33 kalisto generate_smb4_conf.py: [common.pipesubr:66] Popen()ing: /usr/local/bin/net -d 0 getlocalsid Oct 14 12:15:37 kalisto generate_ldap_conf.py: [common.pipesubr:66] Popen()ing: klist Oct 14 12:15:38 kalisto ActiveDirectory: /usr/local/bin/python /usr/local/www/freenasUI/middleware/notifier.py stop cifs Oct 14 12:15:39 kalisto notifier: winbindd not running? (check /var/run/samba/winbindd.pid). Oct 14 12:15:39 kalisto notifier: smbd not running? (check /var/run/samba/smbd.pid). Oct 14 12:15:39 kalisto notifier: nmbd not running? (check /var/run/samba/nmbd.pid). Oct 14 12:15:40 kalisto ActiveDirectory: /usr/sbin/service ix-kerberos quietstop Oct 14 12:15:40 kalisto ActiveDirectory: /usr/sbin/service ix-nsswitch quietstop Oct 14 12:15:40 kalisto ActiveDirectory: /usr/sbin/service ix-pam quietstop Oct 14 12:15:40 kalisto ActiveDirectory: /usr/sbin/service ix-activedirectory forcestop Oct 14 12:15:42 kalisto adtool: [common.pipesubr:66] Popen()ing: klist Oct 14 12:15:43 kalisto ActiveDirectory: /usr/sbin/service ix-cache quietstop & Oct 14 12:15:43 kalisto ActiveDirectory: /usr/sbin/service samba_server forcestop Oct 14 12:15:44 kalisto ActiveDirectory: /usr/sbin/service ix-pre-samba start Oct 14 12:15:45 kalisto generate_smb4_conf.py: [common.pipesubr:66] Popen()ing: /sbin/sysctl -n 'kern.maxfilesperproc' Oct 14 12:15:45 kalisto generate_smb4_conf.py: [common.pipesubr:66] Popen()ing: mount Oct 14 12:15:45 kalisto generate_smb4_conf.py: [common.pipesubr:66] Popen()ing: /usr/local/bin/net -d 0 getlocalsid Oct 14 12:15:45 kalisto ActiveDirectory: /usr/sbin/service ix-kinit forcestop Oct 14 12:15:45 kalisto ActiveDirectory: /usr/sbin/service ix-hostname quietstart Oct 14 12:15:46 kalisto smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 Oct 14 12:27:23 kalisto smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2 Oct 14 12:27:24 kalisto smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3 Oct 14 12:27:24 kalisto mDNSResponder: mDNSResponder (Engineering Build) (Oct 3 2016 06:58:50) starting Oct 14 12:27:24 kalisto mDNSResponder: 8: Listening for incoming Unix Domain Socket client requests Oct 14 12:27:24 kalisto mDNSResponder: mDNS_AddDNSServer: Lock not held! mDNS_busy (0) mDNS_reentrancy (0) Oct 14 12:27:24 kalisto mDNSResponder: mDNS_AddDNSServer: Lock not held! mDNS_busy (0) mDNS_reentrancy (0) Oct 14 12:27:24 kalisto mDNSResponder: CheckNATMappings: Failed to allocate port 5350 UDP multicast socket for PCP & NAT-PMP announcements Oct 14 12:27:25 kalisto mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000801406D60 kalisto.local. (Addr) that's already in the list Oct 14 12:27:25 kalisto mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000801407180 27.1.1.10.in-addr.arpa. (PTR) that's already in the list Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $growfs_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $ is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $vmware_guest__enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $tcsd_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $stunnel_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $nut_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $nut_upslog_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $nut_upsmon_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $xenguest_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $snmptrapd_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $rrdcached_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $openvpn_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $mdnsresponderposix_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $kpropd_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $iohyve_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $htcacheclean_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $git_daemon_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $django_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $consul_alerts_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $consul_enable is not set properly - see rc.conf(5). Oct 14 12:30:48 kalisto root: /usr/sbin/service: WARNING: $collectdmon_enable is not set properly - see rc.conf(5). Oct 14 12:21:14 kalisto ntpd[2487]: frequency error -2028543 PPM exceeds tolerance 500 PPM Oct 14 12:21:14 kalisto mDNSResponder: mDNSCoreReceive: mDNSPlatformRawTime went backwards by 711886 ticks; setting correction factor to 2304627488 Oct 14 12:30:57 kalisto manage.py: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name
Oct 14 12:51:30 kalisto pcib34: <ACPI PCI-PCI bridge> at device 24.7 on pci0 Oct 14 12:51:30 kalisto pci34: <ACPI PCI bus> on pcib34 Oct 14 12:51:30 kalisto acpi_acad0: <AC Adapter> on acpi0 Oct 14 12:51:30 kalisto atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0 Oct 14 12:51:30 kalisto atkbd0: <AT Keyboard> irq 1 on atkbdc0 Oct 14 12:51:30 kalisto kbd0 at atkbd0 Oct 14 12:51:30 kalisto atkbd0: [GIANT-LOCKED] Oct 14 12:51:30 kalisto psm0: <PS/2 Mouse> irq 12 on atkbdc0 Oct 14 12:51:30 kalisto psm0: [GIANT-LOCKED] Oct 14 12:51:30 kalisto psm0: model IntelliMouse, device ID 3 Oct 14 12:51:30 kalisto uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0 Oct 14 12:51:30 kalisto uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0 Oct 14 12:51:30 kalisto orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc9fff,0xca000-0xcafff,0xdc000-0xdffff,0xe0000-0xe7fff on isa0 Oct 14 12:51:30 kalisto sc0: <System console> at flags 0x100 on isa0 Oct 14 12:51:30 kalisto sc0: VGA <16 virtual consoles, flags=0x300> Oct 14 12:51:30 kalisto vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0 Oct 14 12:51:30 kalisto coretemp0: <CPU On-Die Thermal Sensors> on cpu0 Oct 14 12:51:30 kalisto coretemp0: Tj(target) value 0 does not seem right. Oct 14 12:51:30 kalisto ZFS filesystem version: 5 Oct 14 12:51:30 kalisto ZFS storage pool version: features support (5000) Oct 14 12:51:30 kalisto Timecounters tick every 1.000 msec Oct 14 12:51:30 kalisto ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled Oct 14 12:51:30 kalisto random: unblocking device. Oct 14 12:51:30 kalisto da0 at mpt0 bus 0 scbus2 target 0 lun 0 Oct 14 12:51:30 kalisto da0: <VMware Virtual disk 1.0> Fixed Direct Access SCSI-2 device Oct 14 12:51:30 kalisto da0: 320.000MB/s transfers (160.000MHz DT, offset 127, 16bit) Oct 14 12:51:30 kalisto da0: Command Queueing enabled Oct 14 12:51:30 kalisto da0: 10240MB (20971520 512 byte sectors) Oct 14 12:51:30 kalisto da0: quirks=0x40<RETRY_BUSY> Oct 14 12:51:30 kalisto da1 at mpt0 bus 0 scbus2 target 1 lun 0 Oct 14 12:51:30 kalisto da1: <VMware Virtual disk 1.0> Fixed Direct Access SCSI-2 device Oct 14 12:51:30 kalisto da1: 320.000MB/s transfers (160.000MHz DT, offset 127, 16bit) Oct 14 12:51:30 kalisto da1: Command Queueing enabled Oct 14 12:51:30 kalisto da1: 10240MB (20971520 512 byte sectors) Oct 14 12:51:30 kalisto da1: quirks=0x40<RETRY_BUSY> Oct 14 12:51:30 kalisto cd0 at ata1 bus 0 scbus1 target 0 lun 0 Oct 14 12:51:30 kalisto cd0: <NECVMWar VMware IDE CDR10 1.00> Removable CD-ROM SCSI device Oct 14 12:51:30 kalisto cd0: Serial Number 10000000000000000001 Oct 14 12:51:30 kalisto cd0: 33.300MB/s transfers (UDMA2, ATAPI 12bytes, PIO 65534bytes) Oct 14 12:51:30 kalisto cd0: Attempt to query device size failed: NOT READY, Medium not present Oct 14 12:51:30 kalisto cd0: quirks=0x40<RETRY_BUSY> Oct 14 12:51:30 kalisto Timecounter "TSC-low" frequency 1197227500 Hz quality 1000 Oct 14 12:51:30 kalisto Trying to mount root from zfs:freenas-boot/ROOT/default []... Oct 14 12:51:30 kalisto GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7) Oct 14 12:51:30 kalisto hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/0/0/0x67<INT,USR,SYS,REA,WRI> Oct 14 12:51:30 kalisto VMware memory control driver initialized Oct 14 12:51:30 kalisto kernel: vmx0: link state changed to UP Oct 14 12:51:30 kalisto kernel: vmx0: link state changed to UP Oct 14 12:51:30 kalisto root: /etc/rc: WARNING: failed to start watchdogd Oct 14 12:51:31 kalisto GEOM_ELI: Device da1p1.eli created. Oct 14 12:51:31 kalisto GEOM_ELI: Encryption: AES-XTS 128 Oct 14 12:51:31 kalisto GEOM_ELI: Crypto: hardware Oct 14 12:51:31 kalisto ntpd[1723]: ntpd 4.2.8p8-a (1): Starting Oct 14 12:51:33 kalisto generate_smb4_conf.py: [generate_smb4_conf:1498] Unable to open /var/db/samba4/private/secrets.tdb: [Errno 2] No such file or directory Oct 14 12:51:33 kalisto generate_smb4_conf.py: [common.pipesubr:66] Popen()ing: /sbin/sysctl -n 'kern.maxfilesperproc' Oct 14 12:51:33 kalisto generate_smb4_conf.py: [common.pipesubr:66] Popen()ing: mount Oct 14 12:51:33 kalisto generate_smb4_conf.py: [common.pipesubr:66] Popen()ing: /usr/local/bin/net -d 0 getlocalsid Oct 14 13:03:12 kalisto mDNSResponder: mDNSResponder (Engineering Build) (Oct 3 2016 06:58:50) starting Oct 14 13:03:12 kalisto mDNSResponder: 8: Listening for incoming Unix Domain Socket client requests Oct 14 13:03:12 kalisto mDNSResponder: mDNS_AddDNSServer: Lock not held! mDNS_busy (0) mDNS_reentrancy (0) Oct 14 13:03:12 kalisto mDNSResponder: mDNS_AddDNSServer: Lock not held! mDNS_busy (0) mDNS_reentrancy (0) Oct 14 13:03:12 kalisto mDNSResponder: CheckNATMappings: Failed to allocate port 5350 UDP multicast socket for PCP & NAT-PMP announcements Oct 14 13:03:17 kalisto mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000801406D60 kalisto.local. (Addr) that's already in the list Oct 14 13:03:17 kalisto mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000801407180 27.1.1.10.in-addr.arpa. (PTR) that's already in the list
Oct 14 12:58:54 kalisto pcib33: <ACPI PCI-PCI bridge> at device 24.6 on pci0 Oct 14 12:58:54 kalisto pci33: <ACPI PCI bus> on pcib33 Oct 14 12:58:54 kalisto pcib34: <ACPI PCI-PCI bridge> at device 24.7 on pci0 Oct 14 12:58:54 kalisto pci34: <ACPI PCI bus> on pcib34 Oct 14 12:58:54 kalisto acpi_acad0: <AC Adapter> on acpi0 Oct 14 12:58:54 kalisto atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0 Oct 14 12:58:54 kalisto atkbd0: <AT Keyboard> irq 1 on atkbdc0 Oct 14 12:58:54 kalisto kbd0 at atkbd0 Oct 14 12:58:54 kalisto atkbd0: [GIANT-LOCKED] Oct 14 12:58:54 kalisto psm0: <PS/2 Mouse> irq 12 on atkbdc0 Oct 14 12:58:54 kalisto psm0: [GIANT-LOCKED] Oct 14 12:58:54 kalisto psm0: model IntelliMouse, device ID 3 Oct 14 12:58:54 kalisto uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0 Oct 14 12:58:54 kalisto uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0 Oct 14 12:58:54 kalisto orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc9fff,0xca000-0xcafff,0xdc000-0xdffff,0xe0000-0xe7fff on isa0 Oct 14 12:58:54 kalisto sc0: <System console> at flags 0x100 on isa0 Oct 14 12:58:54 kalisto sc0: VGA <16 virtual consoles, flags=0x300> Oct 14 12:58:54 kalisto vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0 Oct 14 12:58:54 kalisto coretemp0: <CPU On-Die Thermal Sensors> on cpu0 Oct 14 12:58:54 kalisto coretemp0: Tj(target) value 0 does not seem right. Oct 14 12:58:54 kalisto ZFS filesystem version: 5 Oct 14 12:58:54 kalisto ZFS storage pool version: features support (5000) Oct 14 12:58:54 kalisto Timecounters tick every 1.000 msec Oct 14 12:58:54 kalisto ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled Oct 14 12:58:54 kalisto random: unblocking device. Oct 14 12:58:54 kalisto da0 at mpt0 bus 0 scbus2 target 0 lun 0 Oct 14 12:58:54 kalisto da0: <VMware Virtual disk 1.0> Fixed Direct Access SCSI-2 device Oct 14 12:58:54 kalisto da0: 320.000MB/s transfers (160.000MHz DT, offset 127, 16bit) Oct 14 12:58:54 kalisto da0: Command Queueing enabled Oct 14 12:58:54 kalisto da0: 10240MB (20971520 512 byte sectors) Oct 14 12:58:54 kalisto da0: quirks=0x40<RETRY_BUSY> Oct 14 12:58:54 kalisto da1 at mpt0 bus 0 scbus2 target 1 lun 0 Oct 14 12:58:54 kalisto da1: <VMware Virtual disk 1.0> Fixed Direct Access SCSI-2 device Oct 14 12:58:54 kalisto da1: 320.000MB/s transfers (160.000MHz DT, offset 127, 16bit) Oct 14 12:58:54 kalisto da1: Command Queueing enabled Oct 14 12:58:54 kalisto da1: 10240MB (20971520 512 byte sectors) Oct 14 12:58:54 kalisto da1: quirks=0x40<RETRY_BUSY> Oct 14 12:58:54 kalisto cd0 at ata1 bus 0 scbus1 target 0 lun 0 Oct 14 12:58:54 kalisto cd0: <NECVMWar VMware IDE CDR10 1.00> Removable CD-ROM SCSI device Oct 14 12:58:54 kalisto cd0: Serial Number 10000000000000000001 Oct 14 12:58:54 kalisto cd0: 33.300MB/s transfers (UDMA2, ATAPI 12bytes, PIO 65534bytes) Oct 14 12:58:54 kalisto cd0: Attempt to query device size failed: NOT READY, Medium not present Oct 14 12:58:54 kalisto cd0: quirks=0x40<RETRY_BUSY> Oct 14 12:58:54 kalisto Timecounter "TSC-low" frequency 1197227500 Hz quality 1000 Oct 14 12:58:54 kalisto Trying to mount root from zfs:freenas-boot/ROOT/9.10.1-U2 []... Oct 14 12:58:54 kalisto GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7) Oct 14 12:58:54 kalisto hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/0/0/0x67<INT,USR,SYS,REA,WRI> Oct 14 12:58:54 kalisto VMware memory control driver initialized Oct 14 12:58:54 kalisto kernel: vmx0: link state changed to UP Oct 14 12:58:54 kalisto kernel: vmx0: link state changed to UP Oct 14 12:58:55 kalisto root: /etc/rc: WARNING: failed to start watchdogd Oct 14 12:58:56 kalisto GEOM_ELI: Device da1p1.eli created. Oct 14 12:58:56 kalisto GEOM_ELI: Encryption: AES-XTS 128 Oct 14 12:58:56 kalisto GEOM_ELI: Crypto: hardware Oct 14 12:58:56 kalisto ntpd[1723]: ntpd 4.2.8p8-a (1): Starting Oct 14 12:58:58 kalisto generate_smb4_conf.py: [generate_smb4_conf:1498] Unable to open /var/db/samba4/private/secrets.tdb: [Errno 2] No such file or directory Oct 14 12:58:58 kalisto generate_smb4_conf.py: [common.pipesubr:66] Popen()ing: /sbin/sysctl -n 'kern.maxfilesperproc' Oct 14 12:58:59 kalisto generate_smb4_conf.py: [common.pipesubr:66] Popen()ing: mount Oct 14 12:58:59 kalisto generate_smb4_conf.py: [common.pipesubr:66] Popen()ing: /usr/local/bin/net -d 0 getlocalsid Oct 14 13:10:37 kalisto mDNSResponder: mDNSResponder (Engineering Build) (Oct 3 2016 06:58:50) starting Oct 14 13:10:37 kalisto mDNSResponder: 8: Listening for incoming Unix Domain Socket client requests Oct 14 13:10:37 kalisto mDNSResponder: mDNS_AddDNSServer: Lock not held! mDNS_busy (0) mDNS_reentrancy (0) Oct 14 13:10:37 kalisto mDNSResponder: mDNS_AddDNSServer: Lock not held! mDNS_busy (0) mDNS_reentrancy (0) Oct 14 13:10:37 kalisto mDNSResponder: CheckNATMappings: Failed to allocate port 5350 UDP multicast socket for PCP & NAT-PMP announcements Oct 14 13:10:43 kalisto mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000801406D60 kalisto.local. (Addr) that's already in the list Oct 14 13:10:43 kalisto mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000801407180 27.1.1.10.in-addr.arpa. (PTR) that's already in the list
Thank you
