maumar
 - Sep 8, 2013
Buongiornoa tutti
ho un NAS con 7 dischi da 3 Tera, un disco e' sacrificato per il boot, gli altri 6 invece sono sonoin RAIDZ2-0
Si e' rotto un disco ed ecco la situazione:
zpool status -x
pool: volraidz2
state: DEGRADED
status: One or more devices could not be opened. Sufficient replicas exist for
the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
see: http://illumos.org/msg/ZFS-8000-2Q
scan: scrub repaired 0 in 16h31m with 0 errors on Sun Aug 25 16:31:13 2013
NAME STATE READ WRITE CKSUM
volraidz2 DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/ad584362-7d1a-11e2-a678-0024219c3544 ONLINE 0 0 0
gptid/adf33495-7d1a-11e2-a678-0024219c3544 ONLINE 0 0 0
gptid/ae71c597-7d1a-11e2-a678-0024219c3544 ONLINE 0 0 0
gptid/aee96670-7d1a-11e2-a678-0024219c3544 ONLINE 0 0 0
16072502205208485062 UNAVAIL 0 0 0 was /dev/gptid/af650245-7d1a-11e2-a678-0024219c3544
gptid/afdc214a-7d1a-11e2-a678-0024219c3544 ONLINE 0 0 0
Ho chiesto a quelli della webfarm di sotituire il disco rotto (il 5^)
Dopo la sostituzione da interfaccia web ho fatto (stupidamente) Add
Non dovevo fare Add
Dovevo fare replace
Il disco addato adesso e' l'ultimo
/dev/gptid/7ede4402-1633-11e3-9227-0024219c3544
Adesso sono in questa situazione
[root@freenas] ~# zpool status
pool: volraidz2
state: DEGRADED
gptid/7ede4402-1633-11e3-9227-0024219c3544 ONLINE 0 0 0
errors: No known data errors
[root@freenas] ~# zpool detach gptid/7ede4402-1633-11e3-9227-0024219c3544
missing <device> specification
usage:
detach <pool> <device>
[root@freenas] ~# zpool detach volraidz2 gptid/7ede4402-1633-11e3-9227-0024219c3544
cannot detach gptid/7ede4402-1633-11e3-9227-0024219c3544: only applicable to mirror and replacing vdevs
[root@freenas] ~# zpool remove volraidz2 gptid/7ede4402-1633-11e3-9227-0024219c3544
cannot remove gptid/7ede4402-1633-11e3-9227-0024219c3544: only inactive hot spares, cache, top-level, or log devices can be removed
[root@freenas] ~# zpool replace volraidz2 gptid/af650245-7d1a-11e2-a678-0024219c3544 gptid/7ede4402-1633-11e3-9227-0024219c3544
invalid vdev specification
use '-f' to override the following errors:
/dev/gptid/7ede4402-1633-11e3-9227-0024219c3544 is part of active pool 'volraidz2'
Dunque
non mi fa rimuovere
non mi fa fare detach
il replace mi chiede di fare -f, sono sicuro che perdo tutto
Esiste qualche altra via di uscita?
Altrimenti reinstall
Grazie
zpool status -x
pool: volraidz2
state: DEGRADED
Non dovevo fare Add
Dovevo fare replace
pool: volraidz2
state: DEGRADED
usage:
Dunque
non mi fa rimuovere
Grazie
