Bio Hazzard
- Feb 27, 2012
Hey guys, wondering if anyone could help with a little FTP problem
My setup
System Information
Hostname freenas.local
FreeNAS Build FreeNAS-8.0.3-RELEASE-p1-x64 (9591)
Platform Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Memory 1777MB
System Time Mon Feb 27 22:37:07 2012
Uptime 10:37PM up 23 mins, 0 users
Load Average 0.00, 0.00, 0.00
OS Version FreeBSD 8.2-RELEASE-p6
My Problem
I can't quite connect to my FTP server using my external i.p., my internal i.p. works fine and lists the directories though :\ I originally tried port 21 (default) but when using a port checker tool it said it wasn't open, ISP might be blocking it. So I switched to a higher port 23235 (port checker tool confirmed that port was open).
Seeming I can authenticate into the server but can't list the directories it might be a permissions problem but it quite weird how it only affects my external i.p.
I have three disks (2TB each formatted ZFS) and two volumes one being a datasheet
shared /mnt/shared 102.2 GiB (1%) 5.3 TiB 5.4 TiB HEALTHY
shared /mnt/shared/ftpuser 152.0 KiB (0%) 50.0 GiB 50.0 GiB HEALTHY
I have created the following groups:
1001 Bio-Hazzard
1002 Gunter
1003 Windows
1004 ftpuser
And the following users
1001 Bio-Hazzard Bio-Hazzard /mnt/shared /bin/csh
1002 Gunter Gunter /mnt/shared /bin/csh
1003 ftpuser ftpuser /mnt/shared/ftpuser/USERS /bin/csh
My error while using FileZilla
Status: Connecting to ###.###.###.###:#####...
Status: Connection attempt failed with "ECONNREFUSED - Connection refused by server".
Error: Could not connect to server
Status: Connection established, waiting for welcome message...
Response: 220 ProFTPD 1.3.3e Server (freenas.local FTP Server) [::ffff:192.168.0.188]
Command: USER Bio-Hazzard
Response: 331 Password required for Bio-Hazzard
Command: PASS *********
Response: 230-Welcome to Bio Hazzard's FTP server
Response: 230 User Bio-Hazzard logged in
Command: OPTS UTF8 ON
Response: 200 UTF8 set to on
Status: Connected
Status: Retrieving directory listing...
Command: PWD
Response: 257 "/mnt/shared" is the current directory
Command: TYPE I
Response: 200 Type set to I
Command: PASV
Response: 227 Entering Passive Mode (###,###,#,###,###,###).
Status: Server sent passive reply with unroutable address. Using server address instead.
Command: MLSD
Error: Connection timed out
Error: Failed to retrieve directory listing
Any help is greatly appreciated, I've been spending nights on end trying to get the ftp side of things to work!
			My setup
System Information
Memory 1777MB
My Problem
1001 Bio-Hazzard
1002 Gunter
1003 Windows
1004 ftpuser
Status: Connected
Command: PWD
Command: TYPE I
Command: PASV
Command: MLSD
