FTP, can't connect as a user
cpunlimited
Hi all,
I am using the FileZilla client to test out FTP as a user. I can login anonymously, but when I change the settings and try to do it as a user, I get the following response:
Response:    550 SSL/TLS required on the control channel
Anyone know if I need to toggle more settings?
Whattteva
You have TLS checked but you're probably connecting without TLS on FileZilla, so the server rejects it.
cpunlimited
I unchecked the "TLS" box and now its telling me it could not connect to the server.
Here's my user settings, anyone have an idea?:
cpunlimited
Nevermind, I got the problem solved. It had to do with chroot and home directory. Thanks for the help though!
