l@e
 - Nov 4, 2013
Regarding point 2. Maybee you have them configured as maped drive or net drives at client side. You can not make them disapear changing FN conf. Use “net use \\server\share /delete” from cmd.Since doing this, I notice:
1. The Kerberos Realm is now FURRY.LOCAL, whereas before it was / was set to be wse2012r2.furry.local, and KDC, Password Server and Admin Server have nothing defined.
2. I have a previously-defined SMB share which still appears to Windows clients, but which is not defined in the webGUI (e.g. under Sharing), and which I can't get rid of; I've tried detaching the pool etc., which is supposed to destroy all data.
3. I can see the AD accounts listed, in the form (e.g.) "FURRY\freenasadmin" when I edit permissions for a pool / dataset, but these do not appear under "Accounts".
Regarding point 3. The rights for these users you have to set from smb share from any of the clients, just select principal furry domain and not FN. they will not apear as local users on FN. FN will just redirect their SID to th DC to resolve.
