error pool
dio123
Good evening, I built a PC 2 years ago to store personal things.
Every now and then I get this error, but everything is new. All disk , S.M.A.R.T test are ok.
When I receive this error I have to forcefully turn off the PC and turn it back on, then I check the pools and I don't get any errors.
What could it be?All smart discs are ok.
Hardware in subscription
New alerts:
* Pool tank state is ONLINE: One or more devices has experienced an error
resulting in data corruption. Applications may be affected.
joeschmuck
Old Man
Run zpool status and post the results. The error message you are getting has to do with ZFS, not necessarily a hard drive failure. It could also be caused by forcefully powering off the computer.
zpool status -v tank will also show the corrupted files
dio123
good afternoon,
Send the zpool status report.
However, I had to forcefully reconnect the computer because I couldn't log in either via web or ssh.
This situation has happened more than once, it's the 4th time this year.
I installed the thing 2 weeks new kingston ssd and a root installation, and it already gave me the same error.
root@MinhaCasa[~]# zpool status
  pool: MinhaCasa
 state: ONLINE
  scan: scrub repaired 0B in 03:02:23 with 0 errors on Sun Aug 20 03:02:23 2023
        NAME                                          STATE     READ WRITE CKSUM
        MinhaCasa                                     ONLINE       0     0     0
          gptid/707d8f5f-4efc-11ec-900f-1c1b0dba31ee  ONLINE       0     0     0
errors: No known data errors
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:00:03 with 0 errors on Wed Sep 20 03:45:03 2023
          ada0p2    ONLINE       0     0     0
  pool: tank
 state: ONLINE
  scan: scrub repaired 0B in 00:03:39 with 0 errors on Sun Aug 20 00:03:40 2023
        tank                                          ONLINE       0     0     0
          gptid/47adb284-ebfe-11ed-97e3-00e04c6831d2  ONLINE       0     0     0
You should run a scrub on tank (zpool scrub tank) and wait for it to finish before considering all is good.
joeschmuck
Old Man
Yup, I was afraid of that, single drive pools. Keep in mind that you have zero protection. If you loose a file, it's gone. So long as yo understand this risk, all is good. Do as asked, run a scrub and see what the results are.
dio123
Good afternoon, I ran the scrub but it didn't detect any errors. However, I have a WD cloud disk and I always make backups, even if I have a serious problem, I don't have any losses, just install and reset settings and the vm..
pool: tank
 state: ONLINE
  scan: scrub repaired 0B in 00:03:53 with 0 errors on Fri Sep 22 12:43:22 2023
        tank                                          ONLINE       0     0     0
joeschmuck
Old Man
Looks good.
dio123
Good afternoon friends,
I returned to the blocked server only this time, there were people at home who managed to connect to the PC via WiFi and threw the result zpool status -v tank.
I still haven't tried zpool scrub tank but it hasn't been resolved because it was blocked and I just had to restart the server forcibly.
I S.M.A.R.T the disc and it's ok, and it's new from Kingston
After reboot it no longer shows errors the command status -v tank
Image attached.
