jetsurgeon
- Apr 16, 2020
I’m a relatively new FreeNAS user, I have about 2 months experience with FreeNAS under my belt, learning every day from this wonderful knowledge base here on the forum / community, you guys are the best.
In my email today I received 2 error emails from my FreeNAS box about one of my Hitachi / HGST Ultrastar 7K4000 drives. I’ll paste the two email errors below, and the hardware /software specs, along with the output of the “smartctl –a” output for the drive in question, in my case “/dev/da1”.
I don’t want to assume but I believe the drive is failing. I should probably swap it out with a replacement drive, then resilver, but before I do anything I’m looking for some guidance from you more experienced users. Hoping you guys can provide some guidance, I’m new to this stuff……..
Here we go……
Thanks!
Jeff
HARDWARE / SOFTWARE
MB: SUPERMICRO X8SIL-F
CPU: XEON x3470 @ 2.93 GHz
RAM: 32GB ECC (4 X 8Gb ECC 1333 MHz)
SATA Card: LSI SAS 9210-8i in IT Mode
Boot Drive: 128Gb SSD
NAS DRIVES: 8 X 4 TB Hitachi/HGST Ultrastar 7K4000
ZFS: RAID-Z2
FREENAS: 11.3 - U3
Plex: Installed in a Jail
Here we go……
Thanks!
Jeff
HARDWARE / SOFTWARE
ZFS: RAID-Z2
FREENAS: 11.3 - U3
EMAIL ERROR 1 FreeNAS @ freenas.local New alerts: * Device: /dev/da1 [SAT], 8 Currently unreadable (pending) sectors. Current alerts: * Device: /dev/da1 [SAT], 8 Currently unreadable (pending) sectors.
EMAIL ERROR 2 FreeNAS @ freenas.local New alerts: * Device: /dev/da1 [SAT], Self-Test Log error count increased from 0 to 1. Current alerts: * Device: /dev/da1 [SAT], 8 Currently unreadable (pending) sectors. * Device: /dev/da1 [SAT], Self-Test Log error count increased from 0 to 1.
XXX@freenas[~]# smartctl -a /dev/da1
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p9 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Hitachi/HGST Ultrastar 7K4000
Device Model: Hitachi HUS724040ALE641
Serial Number: PAJ3TPYS
LU WWN Device Id: 5 000cca 22bdde8df
Firmware Version: MJAOA5F0
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Jun 23 03:55:20 2020 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x85) Offline data collection activity
was aborted by an interrupting command from host.
been run.
data collection: ( 24) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 086 086 016 Pre-fail Always - 119
2 Throughput_Performance 0x0005 136 136 054 Pre-fail Offline - 80
3 Spin_Up_Time 0x0007 117 117 024 Pre-fail Always - 657 (Average 667)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 15
5 Reallocated_Sector_Ct 0x0033 072 072 005 Pre-fail Always - 678
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 119 119 020 Pre-fail Offline - 35
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 1351
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 15
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 55
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 55
194 Temperature_Celsius 0x0002 130 130 000 Old_age Always - 46 (Min/Max 24/55)
196 Reallocated_Event_Count 0x0032 072 072 000 Old_age Always - 681
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 8
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 1
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 1 occurred at disk power-on lifetime: 987 hours (41 days + 3 hours)
ER ST SC SN CL CH DH
40 51 78 98 7f c7 01 Error: UNC at LBA = 0x01c77f98 = 29851544
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 e8 70 10 87 c7 40 00 2d+21:04:06.397 READ FPDMA QUEUED
60 00 68 10 86 c7 40 00 2d+21:04:06.397 READ FPDMA QUEUED
60 00 38 10 85 c7 40 00 2d+21:04:06.397 READ FPDMA QUEUED
60 00 30 10 84 c7 40 00 2d+21:04:06.397 READ FPDMA QUEUED
60 00 28 10 83 c7 40 00 2d+21:04:06.397 READ FPDMA QUEUED
# 1 Short offline Completed without error 00% 1351 -
# 2 Extended offline Completed: read failure 90% 1345 33801016
# 3 Short offline Completed without error 00% 1273 -
# 4 Short offline Completed without error 00% 1104 -
# 5 Short offline Completed without error 00% 1090 -
# 6 Short offline Completed without error 00% 1090 -
# 7 Short offline Completed without error 00% 1080 -
# 8 Short offline Completed without error 00% 1063 -
# 9 Short offline Completed without error 00% 1056 -
#10 Short offline Completed without error 00% 1039 -
#11 Short offline Completed without error 00% 1039 -
#12 Short offline Completed without error 00% 1032 -
#13 Short offline Completed without error 00% 1008 -
#14 Short offline Completed without error 00% 984 -
#15 Short offline Completed without error 00% 960 -
#16 Short offline Completed without error 00% 936 -
#17 Short offline Completed without error 00% 912 -
#18 Short offline Completed without error 00% 888 -
#19 Short offline Completed without error 00% 864 -
#20 Short offline Completed without error 00% 840 -
#21 Short offline Completed without error 00% 816 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
XXX@freenas[~]#
