Destroy pool and recreate?
blueether
I started doing a disk replace with a old-ish HDD that I had spare as one was degraded with ~1.5k CKSUM
Now that the resilver has started the error count is climbing and the old-ish drive is throwing unreadable (pending) sectors
I have backups of important data on another box, just not the jails
Oct 12 07:46:55 freenas ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
Oct 12 07:46:55 freenas ada2: <ST2000DM001-1E6164 CC43> ATA8-ACS SATA 3.x device
Oct 12 07:46:55 freenas ada2: Serial Number Z1E2K9TC
Oct 12 07:46:55 freenas ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
Oct 12 07:46:55 freenas ada2: 1907729MB (3907029168 512 byte sectors)
Oct 12 07:46:55 freenas ada2: quirks=0x1<4K>
Oct 12 07:49:33 freenas ZFS: vdev state changed, pool_guid=14900235701281331664 vdev_guid=15589422846635699418
Oct 12 09:29:47 freenas smartd[36233]: Device: /dev/ada2, 8 Currently unreadable (pending) sectors
Oct 12 09:29:47 freenas smartd[36233]: Device: /dev/ada2, 8 Offline uncorrectable sectors
undefinedOct 12 09:34:45 freenas smartd[36233]: Device: /dev/ada2, 8 Currently unreadable (pending) sectors
Oct 12 09:34:45 freenas smartd[36233]: Device: /dev/ada2, 8 Offline uncorrectable sectors
Oct 12 09:39:46 freenas smartd[36233]: Device: /dev/ada2, 8 Currently unreadable (pending) sectors
Oct 12 09:39:46 freenas smartd[36233]: Device: /dev/ada2, 8 Offline uncorrectable sectors
Oct 12 09:44:46 freenas smartd[36233]: Device: /dev/ada2, 16 Currently unreadable (pending) sectors (changed +8)
Oct 12 09:44:46 freenas smartd[36233]: Device: /dev/ada2, 16 Offline uncorrectable sectors (changed +8)
Oct 12 09:49:46 freenas smartd[36233]: Device: /dev/ada2, 16 Currently unreadable (pending) sectors
Oct 12 09:49:46 freenas smartd[36233]: Device: /dev/ada2, 16 Offline uncorrectable sectors
Oct 12 09:54:46 freenas smartd[36233]: Device: /dev/ada2, 16 Currently unreadable (pending) sectors
Oct 12 09:54:46 freenas smartd[36233]: Device: /dev/ada2, 16 Offline uncorrectable sectors
Oct 12 09:59:47 freenas smartd[36233]: Device: /dev/ada2, 16 Currently unreadable (pending) sectors
Oct 12 09:59:47 freenas smartd[36233]: Device: /dev/ada2, 16 Offline uncorrectable sectors
Oct 12 10:04:47 freenas smartd[36233]: Device: /dev/ada2, 16 Currently unreadable (pending) sectors
Oct 12 10:04:47 freenas smartd[36233]: Device: /dev/ada2, 16 Offline uncorrectable sectors
Oct 12 10:09:46 freenas smartd[36233]: Device: /dev/ada2, 16 Currently unreadable (pending) sectors
Oct 12 10:09:46 freenas smartd[36233]: Device: /dev/ada2, 16 Offline uncorrectable sectors
Oct 12 10:14:45 freenas smartd[36233]: Device: /dev/ada2, 16 Currently unreadable (pending) sectors
Oct 12 10:14:45 freenas smartd[36233]: Device: /dev/ada2, 16 Offline uncorrectable sectors
Oct 12 10:19:47 freenas smartd[36233]: Device: /dev/ada2, 16 Currently unreadable (pending) sectors
Oct 12 10:19:47 freenas smartd[36233]: Device: /dev/ada2, 16 Offline uncorrectable sectors
Oct 12 10:24:46 freenas smartd[36233]: Device: /dev/ada2, 16 Currently unreadable (pending) sectors
Oct 12 10:24:46 freenas smartd[36233]: Device: /dev/ada2, 16 Offline uncorrectable sectors
Oct 12 10:29:46 freenas smartd[36233]: Device: /dev/ada2, 16 Currently unreadable (pending) sectors
Oct 12 10:29:46 freenas smartd[36233]: Device: /dev/ada2, 16 Offline uncorrectable sectors
Oct 12 10:34:46 freenas smartd[36233]: Device: /dev/ada2, 16 Currently unreadable (pending) sectors
Oct 12 10:34:46 freenas smartd[36233]: Device: /dev/ada2, 16 Offline uncorrectable sectors
Oct 12 10:39:46 freenas smartd[36233]: Device: /dev/ada2, 16 Currently unreadable (pending) sectors
Oct 12 10:39:46 freenas smartd[36233]: Device: /dev/ada2, 16 Offline uncorrectable sectors
root@freenas:~ # zpool status -v IronWolf
  pool: IronWolf
 state: DEGRADED
status: One or more devices is currently being resilvered.  The pool will
        continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
  scan: resilver in progress since Sat Oct 12 07:49:33 2019
        586G scanned at 60.6M/s, 133G issued at 13.8M/s, 1.56T total
        133G resilvered, 8.34% done, 1 days 06:14:24 to go
        NAME                                              STATE     READ WRITE CKSUM
        IronWolf                                          DEGRADED     0     0 1.67K
          mirror-0                                        DEGRADED     0     0 6.66K
            gptid/79d283da-979d-11e8-a256-94de80b75a94    ONLINE       0     0 6.66K
            replacing-1                                   DEGRADED     0     0 4.82K
              gptid/7a8be22e-979d-11e8-a256-94de80b75a94  DEGRADED     0     0 6.66K  too many errors
              gptid/db372b8d-ec57-11e9-9162-001b21981f60  ONLINE       0     0 4.82K
        IronWolf/Media:<0x0>
root@freenas:~ # smartctl -a /dev/ada1
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate IronWolf
Device Model:     ST2000VN004-2E4164
Serial Number:    Z5248MM7
LU WWN Device Id: 5 000c50 0afef4c46
Firmware Version: SC60
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
Rotation Rate:    5900 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Oct 12 11:07:06 2019 NZDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  128) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 277) minutes.
Conveyance self-test routine
SCT capabilities:              (0x10bd) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   112   099   006    Pre-fail  Always       -       42188216
  3 Spin_Up_Time            0x0003   097   095   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   099   099   020    Old_age   Always       -       1464
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   080   060   030    Pre-fail  Always       -       107899659
  9 Power_On_Hours          0x0032   089   089   000    Old_age   Always       -       10109
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       120
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       1
189 High_Fly_Writes         0x003a   001   001   000    Old_age   Always       -       112
190 Airflow_Temperature_Cel 0x0022   069   048   045    Old_age   Always       -       31 (Min/Max 27/37)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       53
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1474
194 Temperature_Celsius     0x0022   031   052   000    Old_age   Always       -       31 (0 15 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%     10109         -
# 2  Short offline       Completed without error       00%     10108         -
# 3  Short offline       Completed without error       00%     10107         -
# 4  Short offline       Completed without error       00%     10106         -
# 5  Short offline       Completed without error       00%     10106         -
# 6  Short offline       Completed without error       00%     10105         -
# 7  Short offline       Completed without error       00%     10104         -
# 8  Short offline       Completed without error       00%     10103         -
# 9  Short offline       Completed without error       00%     10102         -
#10  Short offline       Completed without error       00%     10101         -
#11  Short offline       Completed without error       00%     10100         -
#12  Short offline       Completed without error       00%     10099         -
#13  Short offline       Completed without error       00%     10098         -
#14  Short offline       Completed without error       00%     10097         -
#15  Short offline       Completed without error       00%     10096         -
#16  Short offline       Completed without error       00%     10095         -
#17  Short offline       Completed without error       00%     10095         -
#18  Short offline       Completed without error       00%     10094         -
#19  Short offline       Completed without error       00%     10094         -
#20  Short offline       Completed without error       00%     10093         -
#21  Short offline       Completed without error       00%     10092         -
root@freenas:~ # smartctl -a /dev/ada2
Model Family:     Seagate Barracuda 7200.14 (AF)
Device Model:     ST2000DM001-1E6164
Serial Number:    Z1E2K9TC
LU WWN Device Id: 5 000c50 04f5afad3
Firmware Version: CC43
Rotation Rate:    7200 rpm
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Oct 12 11:08:24 2019 NZDT
See vendor-specific Attribute list for marginal Attributes.
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
Self-test execution status:      ( 249) Self-test routine in progress...
                                        90% of test remaining.
data collection:                (  592) seconds.
capabilities:                    (0x73) SMART execute Offline immediate.
                                        command.
                                        No Offline surface scan supported.
                                        power-saving mode.
recommended polling time:        ( 255) minutes.
SCT capabilities:              (0x3081) SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   112   099   006    Pre-fail  Always       -       132726480
  3 Spin_Up_Time            0x0003   095   095   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   083   083   020    Old_age   Always       -       17982
  7 Seek_Error_Rate         0x000f   067   060   030    Pre-fail  Always       -       21502710673
  9 Power_On_Hours          0x0032   086   086   000    Old_age   Always       -       12688
 12 Power_Cycle_Count       0x0032   083   083   020    Old_age   Always       -       17898
183 Runtime_Bad_Block       0x0032   099   099   000    Old_age   Always       -       1
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       2 3 23
189 High_Fly_Writes         0x003a   099   099   000    Old_age   Always       -       1
190 Airflow_Temperature_Cel 0x0022   061   033   045    Old_age   Always   In_the_past 39 (5 49 39 20 0)
192 Power-Off_Retract_Count 0x0032   092   092   000    Old_age   Always       -       16211
193 Load_Cycle_Count        0x0032   083   083   000    Old_age   Always       -       34183
194 Temperature_Celsius     0x0022   039   067   000    Old_age   Always       -       39 (0 9 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       40
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       40
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       1520h+44m+14.992s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       7568979139
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       10795411086
No Errors Logged
# 1  Short offline       Self-test routine in progress 90%     12688         -
You might be better off removing/offlining (if you can) the failing drive while the resilver completes from the remaining good side of the mirror.
It's not clear if the permanent error means that the copy on the good side of the mirror is also gone (which would be kind of the opposite of the whole point of ZFS... perhaps this was already damaged somehow and just not yet picked up by a scrub?)
blueether
Well finally got a new disk to resilver the mirror
Result:
  pool: IronWolf
 state: DEGRADED
        corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
        entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: resilvered 1.56T in 0 days 05:21:15 with 150 errors on Sat Oct 19 18:11:48 2019
        IronWolf                                          DEGRADED     0     0 1.41K
          mirror-0                                        DEGRADED     0     0 5.61K
            gptid/79d283da-979d-11e8-a256-94de80b75a94    ONLINE       0     0 5.61K
            replacing-1                                   DEGRADED     0     0 4.36K
              gptid/7a8be22e-979d-11e8-a256-94de80b75a94  DEGRADED     0     0 5.61K  too many errors
              gptid/10aa937b-f202-11e9-942d-001b21981f60  ONLINE       0     0 4.36K
Still cant offline the disk that I resilvered
[MiddlewareError: Disk offline failed: "cannot offline /dev/gptid/7a8be22e-979d-11e8-a256-94de80b75a94: no valid replicas, "]
What is with the <0x0>, the non -v would suggest 150 files?
errors: 150 data errors, use '-v' for a list
What are my options now?
blueether
Well, I removed the Dataset and re-scrubbed and all errors have now gone, Not really what I wanted but I do but I do have a backup of the Media Dataset so nothing should be lost
