hugovsky
- Dec 12, 2011
Hi all.
Hope someone could give me a hand on this. Only tested with this version. Can't compare with older versions of freenas.
Build FreeNAS-9.2.1.3-RELEASE-x64 (dc0c46b)
Platform Intel(R) Pentium(R) CPU G2030 @ 3.00GHz
pool and zfs upgraded
RAIDZ2
4x WD red 3,5"
8GB ram non ecc (yet)
no optimizations whatsoever
Intel Cougar Point AHCI SATA controller
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD10EFRX-68JCSN0 01.01A01> ATA-8 SATA 3.x device
ada0: Serial Number WD-WMC1U5671723
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K>
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <WDC WD10EFRX-68PJCN0 01.01A01> ATA-9 SATA 3.x device
ada1: Serial Number WD-WCC4J1725751
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada1: quirks=0x1<4K>
ada2 at ahcich4 bus 0 scbus2 target 0 lun 0
ada2: <WDC WD10EFRX-68JCSN0 01.01A01> ATA-8 SATA 3.x device
ada2: Serial Number WD-WMC1U5213900
ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada2: quirks=0x1<4K>
ada3 at ahcich5 bus 0 scbus3 target 0 lun 0
ada3: <WDC WD10EFRX-68JCSN0 01.01A01> ATA-8 SATA 3.x device
ada3: Serial Number WD-WMC1U5672714
ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada3: quirks=0x1<4K>
Problem:
dd if=/dev/zero of=tmp.dat bs=2048k count=50k
51200+0 records in
51200+0 records out
107374182400 bytes transferred in 701.048828 secs (153162202 bytes/sec)
dd if=tmp.dat of=/dev/null bs=2048k count=50k
51200+0 records in
51200+0 records out
107374182400 bytes transferred in 1615.517868 secs (66464249 bytes/sec)
The dataset does not have compression enabled.
TOP coomand data and graphs from disks attached.
RAIDZ2
4x WD red 3,5"
Problem:
51200+0 records in
51200+0 records out
51200+0 records in
51200+0 records out
