Paul Collins
- Aug 28, 2014
I am having an issue with CIFS not starting on my FreeNAS system. I am a bit of a noob so please forgive me!
I have so far spent 6hrs trying to resolve the issue and found some great info on the Forums and in the bug tracking system - but I still cant resolve the issue. Some of the things I have tried - I have downgraded to 9.2.0 and that didn't work, I have reinstalled the img on to my USB that the system runs from and that didn't work either!
My set up is -
HP Proliant Microserver N54
2MB Ram
2 x 1TB WD HDD's set up to mirror in RAID 1
I have run Testpram and got the following -
Load smb config files from /usr/local/etc/smb4.conf
max_open_files: increasing sysctl_max (11095) to minimum Windows limit (16384)
rlimit_max: increasing rlimit_max (11095) to minimum Windows limit (16384)
Processing section "[freenas]"
Loaded services file OK.
WARNING: lock directory /var/db/samba4 should have permissions 0755 for browsing to work
WARNING: state directory /var/db/samba4 should have permissions 0755 for browsing to work
WARNING: cache directory /var/db/samba4 should have permissions 0755 for browsing to work
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
Now I can see an issue above which relates to Samba4 - but I don't understand how I can change the permissions to 0755
Am I on the right track with this problem and if so how do I change/add permissions?
Thanks in advance
Paul
My set up is -
2MB Ram
Thanks in advance
Paul
