Its been about 6 years not and I need to build something to backup my existing TrueNas Core 13.0-U6.1 server which has the following specs:
(See my post on the build)
Drive Config:
1SSD drive to boot Truenas and then 7x8TB WD Red Pro 5400 RPM drvies in one pool
5 sata on board and 3 are attached to an SYBA SI-PEX40062 4 Port SATA III PCIe 2.0 x2 card. (1boot and 2 for the Pool)
Current System specs of orginal server
HPE ProLiant ML10 Gen9 Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz. tranplant to Fractal Design R5
HPE 2x (1x16GB) Dual Rank x8 DDR4 Memory Kit 805671-B21
SYBA SI-PEX40062 PCI-Express 2.0 x2 Low Profile Ready SATA III (6.0Gb/s) Controller Card - $37.99
SanDisk SSD PLUS 2.5" 120GB SATA III MLC
7x WD Red 8TB NAS Hard Disk Drive - 5400 RPM
Fractal Design Define R5 Blackout Silent ATX Mid Tower Computer Case
SeaSonic G Series SSR-550RM 550W ATX12V
Intel Pro 1000PT Dual Port Gigabit PCI-e IHBA DelI l X3959
I want to put 4x22TB WD Red Pro drives with 2.5GB and 10GB Nework connectivity. Use case is to back up critical data about (5TB various files sizes) but the lion share is to stream 4K UHD files (32GB to 90GB) and TV Shows (1-15GB) and Mp3's
Im not doing any transcoding but want to have the ability to stream to 2 TV's at the same time and future prood it.
Some people are concerned by the Size of the Drives that Silvering and Scrub could take a long time. With the price of 8TB Red Drives vs 22TB, Cost is a concern and at the 22TB price per GB I cant afford buying a nunch of drives. Can someone please provide insight was the way to go?
I looked at the QNAP TVS-h874 box but its very Pricy and figure I can build something similar to what Ive been in the past for a lot less.
Any Advise would be much appreciated
Guide to Building an HPE ProLiant ML10 Gen9 FreeNAS Server
I wanted to upgrade my old FreeNAS server I built four+ years ago. After doing some research I quickly found out a lot has changed from four years ago and if you are going to build it you might as well use server vs consumer grade parts. Biggest expense is the motherboard and ECC memory. The HPE...
www.truenas.com
Drive Config:
