All drives passed. No errorssmartctl -a /dev/adax
That's not what you have to look. Please provide the output.All drives passed. No errors
Just in case, are you able tozpool offline BIGASSRAID
Try Ctrl + Shift + C.I am taking a screenshot of my Shell. How can I copy it from windows web interface? It doesnt like ctr-C
brings up HTML console of web browserTry Ctrl + Shift + C
Disk 7 root@freenas:~ # smartctl -a /dev/ada7 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD80EFZX-68UW8N0 Serial Number: VK1EH4BY LU WWN Device Id: 5 000cca 3b7d4392a Firmware Version: 83.H0A83 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Dec 24 17:43:58 2023 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 101) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: (1209) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 132 132 054 Pre-fail Offline - 112 3 Spin_Up_Time 0x0007 175 175 024 Pre-fail Always - 355 (Average 398) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 54 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18 9 Power_On_Hours 0x0012 093 093 000 Old_age Always - 55389 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 54 22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100 192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 2336 193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 2336 194 Temperature_Celsius 0x0002 176 176 000 Old_age Always - 34 (Min/Max 18/52) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 55377 - # 2 Short offline Completed without error 00% 55356 - # 3 Short offline Completed without error 00% 55332 - # 4 Short offline Completed without error 00% 55308 - # 5 Short offline Completed without error 00% 55296 - # 6 Short offline Completed without error 00% 55284 - # 7 Extended offline Completed without error 00% 55260 - # 8 Short offline Completed without error 00% 55212 - # 9 Short offline Completed without error 00% 55164 - #10 Short offline Completed without error 00% 55140 - #11 Short offline Completed without error 00% 55116 - #12 Short offline Completed without error 00% 55092 - #13 Short offline Completed without error 00% 55068 - #14 Short offline Completed without error 00% 55044 - #15 Short offline Completed without error 00% 55020 - #16 Short offline Completed without error 00% 54996 - #17 Short offline Completed without error 00% 54972 - #18 Short offline Completed without error 00% 54948 - #19 Short offline Completed without error 00% 54924 - #20 Extended offline Completed without error 00% 54890 - #21 Short offline Completed without error 00% 54852 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing
Disk 6 root@freenas:~ # smartctl -a /dev/ada6 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD80EFZX-68UW8N0 Serial Number: VK1EBZTY LU WWN Device Id: 5 000cca 3b7d42d59 Firmware Version: 83.H0A83 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Dec 24 17:49:59 2023 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 101) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: (1150) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 129 129 054 Pre-fail Offline - 124 3 Spin_Up_Time 0x0007 174 174 024 Pre-fail Always - 356 (Average 398) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 55 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18 9 Power_On_Hours 0x0012 093 093 000 Old_age Always - 55389 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 55 22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100 192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 2350 193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 2350 194 Temperature_Celsius 0x0002 181 181 000 Old_age Always - 33 (Min/Max 18/49) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 55376 - # 2 Short offline Completed without error 00% 55356 - # 3 Short offline Completed without error 00% 55332 - # 4 Short offline Completed without error 00% 55308 - # 5 Short offline Completed without error 00% 55296 - # 6 Short offline Completed without error 00% 55284 - # 7 Extended offline Completed without error 00% 55249 - # 8 Short offline Completed without error 00% 55212 - # 9 Short offline Completed without error 00% 55164 - #10 Short offline Completed without error 00% 55140 - #11 Short offline Completed without error 00% 55116 - #12 Short offline Completed without error 00% 55092 - #13 Short offline Completed without error 00% 55068 - #14 Short offline Completed without error 00% 55044 - #15 Short offline Completed without error 00% 55020 - #16 Short offline Completed without error 00% 54996 - #17 Short offline Completed without error 00% 54972 - #18 Short offline Completed without error 00% 54948 - #19 Short offline Completed without error 00% 54924 - #20 Extended offline Completed without error 00% 54889 - #21 Short offline Completed without error 00% 54852 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing
elective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. root@freenas:~ # smartctl -a /dev/ada5 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD80EFZX-68UW8N0 Serial Number: VK1EXGGY LU WWN Device Id: 5 000cca 3b7d46b30 Firmware Version: 83.H0A83 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Dec 24 17:52:22 2023 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 101) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: (1083) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 132 132 054 Pre-fail Offline - 112 3 Spin_Up_Time 0x0007 172 172 024 Pre-fail Always - 361 (Average 404) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 55 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18 9 Power_On_Hours 0x0012 093 093 000 Old_age Always - 55389 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 55 22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100 192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 2338 193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 2338 194 Temperature_Celsius 0x0002 181 181 000 Old_age Always - 33 (Min/Max 18/50) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 55377 - # 2 Short offline Completed without error 00% 55356 - # 3 Short offline Completed without error 00% 55332 - # 4 Short offline Completed without error 00% 55308 - # 5 Short offline Completed without error 00% 55296 - # 6 Short offline Completed without error 00% 55284 - # 7 Extended offline Completed without error 00% 55250 - # 8 Short offline Completed without error 00% 55212 - # 9 Short offline Completed without error 00% 55164 - #10 Short offline Completed without error 00% 55140 - #11 Short offline Completed without error 00% 55116 - #12 Short offline Completed without error 00% 55092 - #13 Short offline Completed without error 00% 55068 - #14 Short offline Completed without error 00% 55044 - #15 Short offline Completed without error 00% 55020 - #16 Short offline Completed without error 00% 54996 - #17 Short offline Completed without error 00% 54972 - #18 Short offline Completed without error 00% 54948 - #19 Short offline Completed without error 00% 54924 - #20 Extended offline Completed without error 00% 54888 - #21 Short offline Completed without error 00% 54852 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing
root@freenas:~ # smartctl -a /dev/ada4 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD80EFZX-68UW8N0 Serial Number: VK1GJA0Y LU WWN Device Id: 5 000cca 3b7d4b1f9 Firmware Version: 83.H0A83 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Dec 24 17:53:54 2023 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 101) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: (1376) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 131 131 054 Pre-fail Offline - 116 3 Spin_Up_Time 0x0007 170 170 024 Pre-fail Always - 365 (Average 409) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 54 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18 9 Power_On_Hours 0x0012 093 093 000 Old_age Always - 55389 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 54 22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100 192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 2347 193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 2347 194 Temperature_Celsius 0x0002 187 187 000 Old_age Always - 32 (Min/Max 19/49) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 55377 - # 2 Short offline Completed without error 00% 55356 - # 3 Short offline Completed without error 00% 55332 - # 4 Short offline Completed without error 00% 55308 - # 5 Short offline Completed without error 00% 55296 - # 6 Short offline Completed without error 00% 55284 - # 7 Extended offline Completed without error 00% 55253 - # 8 Short offline Completed without error 00% 55212 - # 9 Short offline Completed without error 00% 55164 - #10 Short offline Completed without error 00% 55140 - #11 Short offline Completed without error 00% 55116 - #12 Short offline Completed without error 00% 55092 - #13 Short offline Completed without error 00% 55068 - #14 Short offline Completed without error 00% 55044 - #15 Short offline Completed without error 00% 55020 - #16 Short offline Completed without error 00% 54996 - #17 Short offline Completed without error 00% 54972 - #18 Short offline Completed without error 00% 54948 - #19 Short offline Completed without error 00% 54924 - #20 Extended offline Completed without error 00% 54893 - #21 Short offline Completed without error 00% 54852 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing
smartctl -a /dev/adaxCode:root@freenas:~ # smartctl -a /dev/ada4 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD80EFZX-68UW8N0 Serial Number: VK1GJA0Y LU WWN Device Id: 5 000cca 3b7d4b1f9 Firmware Version: 83.H0A83 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Dec 24 17:53:54 2023 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 101) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: (1376) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 131 131 054 Pre-fail Offline - 116 3 Spin_Up_Time 0x0007 170 170 024 Pre-fail Always - 365 (Average 409) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 54 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18 9 Power_On_Hours 0x0012 093 093 000 Old_age Always - 55389 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 54 22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100 192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 2347 193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 2347 194 Temperature_Celsius 0x0002 187 187 000 Old_age Always - 32 (Min/Max 19/49) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 55377 - # 2 Short offline Completed without error 00% 55356 - # 3 Short offline Completed without error 00% 55332 - # 4 Short offline Completed without error 00% 55308 - # 5 Short offline Completed without error 00% 55296 - # 6 Short offline Completed without error 00% 55284 - # 7 Extended offline Completed without error 00% 55253 - # 8 Short offline Completed without error 00% 55212 - # 9 Short offline Completed without error 00% 55164 - #10 Short offline Completed without error 00% 55140 - #11 Short offline Completed without error 00% 55116 - #12 Short offline Completed without error 00% 55092 - #13 Short offline Completed without error 00% 55068 - #14 Short offline Completed without error 00% 55044 - #15 Short offline Completed without error 00% 55020 - #16 Short offline Completed without error 00% 54996 - #17 Short offline Completed without error 00% 54972 - #18 Short offline Completed without error 00% 54948 - #19 Short offline Completed without error 00% 54924 - #20 Extended offline Completed without error 00% 54893 - #21 Short offline Completed without error 00% 54852 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay. root@freenas:~ # smartctl -a /dev/ada1 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD80EFZX-68UW8N0 Serial Number: VK1GHX4Y LU WWN Device Id: 5 000cca 3b7d4b06a Firmware Version: 83.H0A83 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Dec 24 17:56:35 2023 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 101) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: (1083) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 131 131 054 Pre-fail Offline - 116 3 Spin_Up_Time 0x0007 175 175 024 Pre-fail Always - 354 (Average 396) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 55 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 1 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18 9 Power_On_Hours 0x0012 093 093 000 Old_age Always - 55389 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 55 22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100 192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 2336 193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 2336 194 Temperature_Celsius 0x0002 157 157 000 Old_age Always - 38 (Min/Max 19/57) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 1 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 55376 - # 2 Short offline Completed without error 00% 55356 - # 3 Short offline Completed without error 00% 55332 - # 4 Short offline Completed without error 00% 55308 - # 5 Short offline Completed without error 00% 55296 - # 6 Short offline Completed without error 00% 55284 - # 7 Extended offline Completed without error 00% 55249 - # 8 Short offline Completed without error 00% 55212 - # 9 Short offline Completed without error 00% 55164 - #10 Short offline Completed without error 00% 55140 - #11 Short offline Completed without error 00% 55116 - #12 Short offline Completed without error 00% 55092 - #13 Short offline Completed without error 00% 55068 - #14 Short offline Completed without error 00% 55044 - #15 Short offline Completed without error 00% 55020 - #16 Short offline Completed without error 00% 54996 - #17 Short offline Completed without error 00% 54972 - #18 Short offline Completed without error 00% 54948 - #19 Short offline Completed without error 00% 54924 - #20 Extended offline Completed without error 00% 54888 - #21 Short offline Completed without error 00% 54852 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay. root@freenas:~ # smartctl -a /dev/ada0 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD80EFZX-68UW8N0 Serial Number: VK1EX8HY LU WWN Device Id: 5 000cca 3b7d46a77 Firmware Version: 83.H0A83 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Dec 24 17:57:22 2023 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 101) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: (1083) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 130 130 054 Pre-fail Offline - 120 3 Spin_Up_Time 0x0007 173 173 024 Pre-fail Always - 358 (Average 401) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 55 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18 9 Power_On_Hours 0x0012 093 093 000 Old_age Always - 55390 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 55 22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100 192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 2343 193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 2343 194 Temperature_Celsius 0x0002 176 176 000 Old_age Always - 34 (Min/Max 18/53) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 55378 - # 2 Short offline Completed without error 00% 55357 - # 3 Short offline Completed without error 00% 55333 - # 4 Short offline Completed without error 00% 55309 - # 5 Short offline Completed without error 00% 55297 - # 6 Short offline Completed without error 00% 55285 - # 7 Extended offline Completed without error 00% 55250 - # 8 Short offline Completed without error 00% 55213 - # 9 Short offline Completed without error 00% 55165 - #10 Short offline Completed without error 00% 55141 - #11 Short offline Completed without error 00% 55117 - #12 Short offline Completed without error 00% 55093 - #13 Short offline Completed without error 00% 55069 - #14 Short offline Completed without error 00% 55045 - #15 Short offline Completed without error 00% 55021 - #16 Short offline Completed without error 00% 54997 - #17 Short offline Completed without error 00% 54973 - #18 Short offline Completed without error 00% 54949 - #19 Short offline Completed without error 00% 54925 - #20 Extended offline Completed without error 00% 54889 - #21 Short offline Completed without error 00% 54853 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing
root@freenas:~ # smartctl -a /dev/ada2 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD80EFZX-68UW8N0 Serial Number: VJH5RDPX LU WWN Device Id: 5 000cca 261d0b17b Firmware Version: 83.H0A83 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Dec 24 18:00:20 2023 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 101) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: (1150) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 128 128 054 Pre-fail Offline - 128 3 Spin_Up_Time 0x0007 174 174 024 Pre-fail Always - 357 (Average 400) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 50 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18 9 Power_On_Hours 0x0012 093 093 000 Old_age Always - 55389 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 50 22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100 192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 2332 193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 2332 194 Temperature_Celsius 0x0002 157 157 000 Old_age Always - 38 (Min/Max 18/54) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 55376 - # 2 Short offline Completed without error 00% 55356 - # 3 Short offline Completed without error 00% 55332 - # 4 Short offline Completed without error 00% 55308 - # 5 Short offline Completed without error 00% 55296 - # 6 Short offline Completed without error 00% 55284 - # 7 Extended offline Completed without error 00% 55249 - # 8 Short offline Completed without error 00% 55212 - # 9 Short offline Completed without error 00% 55164 - #10 Short offline Completed without error 00% 55140 - #11 Short offline Completed without error 00% 55116 - #12 Short offline Completed without error 00% 55092 - #13 Short offline Completed without error 00% 55068 - #14 Short offline Completed without error 00% 55044 - #15 Short offline Completed without error 00% 55020 - #16 Short offline Completed without error 00% 54996 - #17 Short offline Completed without error 00% 54972 - #18 Short offline Completed without error 00% 54948 - #19 Short offline Completed without error 00% 54924 - #20 Extended offline Completed without error 00% 54889 - #21 Short offline Completed without error 00% 54852 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing
root@freenas:~ # smartctl -a /dev/ada3 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: SandForce Driven SSDs Device Model: SanDisk SDSSDA120G Serial Number: 172773801991 LU WWN Device Id: 5 001b44 8b404ebe5 Firmware Version: Z33130RL User Capacity: 120,034,123,776 bytes [120 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches TRIM Command: Available, deterministic, zeroed Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 T13/2015-D revision 3 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Dec 24 18:01:12 2023 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 120) seconds. Offline data collection capabilities: (0x11) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. No Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 10) minutes. SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 5 Retired_Block_Count 0x0032 100 100 000 Old_age Always - 0 9 Power_On_Hours_and_Msec 0x0032 000 100 000 Old_age Always - 54108h+00m+00.000s 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 56 165 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 21478965297 166 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 167 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 168 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 1 169 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 170 Reserve_Block_Count 0x0032 100 100 000 Old_age Always - 0 171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0 172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0 173 Unknown_SandForce_Attr 0x0032 100 100 000 Old_age Always - 0 174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 33 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 194 Temperature_Celsius 0x0022 070 053 000 Old_age Always - 30 (Min/Max 0/47) 199 SATA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0 230 Life_Curve_Status 0x0032 100 100 000 Old_age Always - 68719607824 232 Available_Reservd_Space 0x0033 100 100 004 Pre-fail Always - 100 233 SandForce_Internal 0x0032 100 100 000 Old_age Always - 20 234 SandForce_Internal 0x0032 100 100 000 Old_age Always - 227 241 Lifetime_Writes_GiB 0x0030 253 253 000 Old_age Offline - 88 242 Lifetime_Reads_GiB 0x0030 253 253 000 Old_age Offline - 2523 244 Unknown_Attribute 0x0032 000 100 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged
