I have a server where old hard drives go to die. It's basically a failover machine that's meant to be used in the event that the primary server *and* the first replication fail. Just wanted to see if anyone can challenge the age on these drives!
For those of you interested, this system is configured as two-six disk Z1 VDEVs plus a hot spare.
Ignore all of the data for ada0 -- it's an Intel SSD that reports power on hours in a different format.
+------+----------+----+-----+-----+-----+-------+-------+--------+------+------+------+-------+----+ |Device|Serial |Temp|Power|Start|Spin |ReAlloc|Current|Offline |UDMA |Seek |High |Command|Last| | | | |On |Stop |Retry|Sectors|Pending|Uncorrec|CRC |Errors|Fly |Timeout|Test| | | | |Hours|Count|Count| |Sectors|Sectors |Errors| |Writes|Count |Age | +------+----------+----+-----+-----+-----+-------+-------+--------+------+------+------+-------+----+ |ada0 |CVCV238603| |91705| | | 0| | | | N/A| N/A| N/A|3821| |ada1 |5YD | 32 |17248| 69| 0| 0| 0| 0| 0| 0| 0| 0| 0| |ada2 !|9XW | 34 |31448| 1043| 0| 126| 21| 21| 0| 447| 4| 33| 0| |ada3 |6XW | 33 |32619| 6962| 0| 0| 0| 0| 0| 6136| 64|4295163| 0| |ada4 |6XW | 33 |49130| 7018| 0| 0| 0| 0| 0| 3341| 25| 1| 0| |ada5 !|6XW | 32 |44704| 4299| 0| 391| 0| 0| 0| 471| 241| 55| 0| |da0 |MK0331YHG | 40 |37360| 8806| 0| 0| 0| 0| 0| N/A| N/A| N/A| 0| |da1 |MK0311YHG | 40 |37439| 5531| 0| 0| 0| 0| 0| N/A| N/A| N/A| 0| |da2 ! |MK0311YHG | 39 |33466| 5578| 0| 37| 6| 0| 5| N/A| N/A| N/A| 0| |da3 |MK0311YHG | 38 |28373| 5471| 0| 0| 0| 0| 1| N/A| N/A| N/A| 0| |da4 |MK0311YHG | 39 |37637| 8882| 0| 0| 0| 0| 0| N/A| N/A| N/A| 0| |da5 |MK0331YHG | 40 |37340| 8772| 0| 0| 0| 0| 0| N/A| N/A| N/A| 0| |da6 |MK0331YHG | 40 |34896| 5864| 0| 0| 0| 0| 0| N/A| N/A| N/A| 0| |da7 |MK0331YHG | 38 |37355| 8756| 0| 0| 0| 0| 0| N/A| N/A| N/A| 0| +------+---------------+----+-----+-----+-----+-------+-------+--------+------+------+------+-------+----+
