Bidule0hm
Server Electronics Sorcerer
- Aug 5, 2013
I just wanted to share my list of useful commands with everyone ;)
Please note that you're the only one responsible of what you do in the CLI so don't blame me if you mess your system.
Feel free to suggest me some commands (by private message to avoid cluttering the thread) ;)
Also I want to say thanks to BigDave for providing some of the commands :)
ZFS
SMART
HDD
HBA
UPS
Misc
Burn-in/Benchmark
ZFS
zpool status -v #shows zpool status infos zpool iostat 1 #shows IOps and R/W bandwidth every second zfs list -t snapshot #lists all the snapshots, add | grep "" to filter arc_summary.py #shows ARC stats arcstat.py #shows ARC stats zdb -C your_pool_name | grep ashift #shows the ashift value
SMART
smartctl -h #shows smart control help, lots of commands examples smartctl -a /dev/daX #shows all smart attributes smartctl -A /dev/daX #same as -a but without vendor infos, last test infos, ... smartctl -l selftest /dev/daX #shows result of last smart test smartctl -l scttemp /dev/daX #shows the temperatures history smartctl -t long /dev/daX #executes a long test (replace "long" by "short" for a short test)
HDD
glabel status #shows gptids and devices names gstat -f daX -I 1000ms #shows IOps and R/W bandwidth every second iostat daX #shows IOps and R/W bandwidth
HBA
dmesg | grep mps #used to check FW and driver versions on HBA cards using the mps driver
UPS
upsc ups #shows all ups attributes (change "ups" with your ups name)
Misc
kldload ipmi.ko #loads ipmitool ipmitool sensor #shows all ipmi sensors values systat -vm #shows system infos (cpu load, ram usage, drives I/O, ...) dmidecode | more #shows all hardware bios infos cat /var/log/messages | more #shows the log (same as in the GUI footer) freenas-debug -h more /var/tmp/fndebug #shows all debug infos camcontrol devlist #shows all devices usbconfig #shows all usb devices
Burn-in/Benchmark
dd if=/dev/zero of=/mnt/tank/tmp.zero bs=2048k count=50k #disable shares and compression for the test!!! dd if=/mnt/tank/tmp.zero of=/dev/null bs=2048k count=50k #disable shares and compression for the test!!! don't forget to delete tmp.zero after diskinfo -t daX #test seek and transfer times for i in 1 2 3 4; do while : ; do : ; done & done #cpu burn test for 4 threads
