Case recommendation
samuelellis
Hi.
I have started to acquire the hardware for my FreeNAS build.
The hardware I have so far is
PSU OCZ 500Watt 80+ PSU - had it for years
HP Proliant ML10 Gen9 - I got this as it was a cheap way to get a ECC compatible board and CPU while offering a fair amount of upgradability
Now as I am planning on having 8 drives they obviously wont fit in the Proliant case so need to look at a new case - I am thinking of the Fractal Design R5 as it can hold 8 3.5 inch drives and strikes a balance between quiet and good cooling performance
Does anyone else have any good case recommendations.
Fractals are great. Im using the XL, which holds 14 3.5" and 4 SSDs via cage addon. I just found one for 85 bucks locally. Well built, good hardware too.
The R5 is very similar to the XL.
samuelellis
Thanks for the recommendation, I was thinking of the fractals as they seem really well built and all the sound-dampening stuff in the case makes it easier to live with
i did look at the XL as it would give me chance to upgrade in future but i think the R5 will have enough as it has the 8 3.5inch drives, space for 2 5.25inch drives i could mount hard drives in and SSD mounts so if i wanted i could put a couple of SSD drives in as well (Cache and log)
CraigD
If you have an 8 drive vdev and want another the same, I think you have two option without going to a rack mountable case
I use a ZALMAN MS800 case. It has 10 5.25" bays. Add 3 3x5.25" to 5 3.5" cages/hot swap bay and your good for 16 Drives
The Antec Twelve Hundred has 12 5.25" bays in theory could hold 20 drives in 4 cages or hot swap bays
You will have to bend some steel tabs out of the way
Have Fun
