- Nov 29, 2021
We are pleased to release TrueNAS SCALE 23.10.1!
This maintenance release addresses community-reported bugs in SCALE 23.10 (Cobia) and improves stability.
Notable changes:
Changelog: https://www.truenas.com/docs/scale/23.10/gettingstarted/scalereleasenotes/#23101-changelog
Download: https://www.truenas.com/download-truenas-scale
Documentation: https://www.truenas.com/docs/scale/23.10/
Thanks for using TrueNAS SCALE! As always, we appreciate your feedback!
Notable changes:
- Reported issues involving cached Web UI artifacts are addressed in 23.10.1 (NAS-124602).
- OpenZFS is updated to version 2.2.2 to fix a data integrity issue discovered in that project (NAS-125541). While this bug has been present in OpenZFS for many years, this issue has not been found to impact any TrueNAS systems to date. See this TrueNAS Community announcement for more details.
- The ZFS block cloning feature is temporarily disabled in 23.10.1. This is being done out of an abundance of caution while the OpenZFS project conducts additional testing. While re-enabling this feature is anticipated in a future 23.10 release, SCALE nightly builds continue to have ZFS block cloning enabled for experimentation and testing.
- Exporting Netdata reporting metrics to a third party database (Graphite) is now supported (NAS-123668).
- The Linux kernel is updated to version 6.1.63 (NAS-125309).
- All network interface hardware addresses persist at upgrade to address a name change some TrueNAS Enterprise system NICs experience when upgrading from TrueNAS SCALE Bluefin to TrueNAS SCALE Cobia (NAS-124679).
- The deprecated Use System Dataset option in System Settings > Advanced > Syslog is removed (WebUI PR #9026).
- Improved sorting and filtering of replace disk search results (NAS-124732).
- Fix issue with immutable fields preventing additional storage configuration for applications (NAS-125196).
- The only install option supported by the 23.10.1 (Cobia) ISO installer is a clean installation. The ISO installer Upgrade Install and Fresh Install options are removed. Only the Fresh Install behavior is supported by the SCALE 23.10.1 (and later versions) ISO file. Continue to use the TrueNAS SCALE update process to seamlessly upgrade from one SCALE major version to another.
