File "/usr/lib/python3/dist-packages/sqlalchemy/engine/base.py", line 1900, in _execute_context
self.dialect.do_execute(
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/default.py", line 736, in do_execute
cursor.execute(statement, parameters)
sqlite3.IntegrityError: UNIQUE constraint failed: storage_volume.vol_name
The above exception was the direct cause of the following exception:
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 426, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 464, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 44, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/import_pool.py", line 181, in import_pool
pool_id = await self.middleware.call('datastore.insert', 'storage.volume', {
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1398, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1341, in _call
File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/write.py", line 62, in insert
result = await self.middleware.call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1352, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1251, in run_in_executor
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/connection.py", line 106, in execute_write
result = self.connection.execute(sql, binds)
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/base.py", line 1365, in execute
return self._exec_driver_sql(
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/base.py", line 1669, in _exec_driver_sql
ret = self._execute_context(
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/base.py", line 1943, in _execute_context
self._handle_dbapi_exception(
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/base.py", line 2124, in _handle_dbapi_exception
util.raise_(
File "/usr/lib/python3/dist-packages/sqlalchemy/util/compat.py", line 211, in raise_
raise exception
sqlalchemy.exc.IntegrityError: (sqlite3.IntegrityError) UNIQUE constraint failed: storage_volume.vol_name
[SQL: INSERT INTO storage_volume (vol_name, vol_guid) VALUES (?, ?)]
[parameters: ('Storage', '10900901337770132667')]
(Background on this error at:
https://sqlalche.me/e/14/gkpj)
