eccevery
- Oct 24, 2014
I have a SuperMicro X9 motherboard that I have used for about two years. A while back I started to get high CPU temp warnings, 89 C, and a really angry beep from the server. Sometimes it hangs, probably because of the high temperature.
The funny thing is, the temperature spikes immediately after boot. If I go into BIOS I get 89 C right away and it stays like that. But if I let FreeNAS boot, the CPU settles at around 60 C once the boot process is complete. If I put some load on the server it goes up again, as expected, but the really high temp so soon after boot seems weird right? I mean, how much load does the CPU have at that point?
The CPU is a E5-2660, but I have tried with a another E5 CPU as well (can't remember the exact model, but the cheapest, least TDP one in the series). Same thing there.
I'm not sure what to do about it. Could there be a faulty sensor? A CPU switch did not change the behaviour, would a motherboard replacement be worth a try?
