CPU temperature difference to IPMI
pakka
Hey there,
Yesterday afternoon suddenly my CPU fan boosted up and first i didn´t bother. Today a had a look into CPU temperatures and fan speed and noticed there is a big difference in that what the ipmi tells and what the freenas UI says. In freenas I have a graph with a temp going up and down, but all above 30°C for the CPU. In IPMI it says the CPU has a constant temperature of 112°C and thats why the fan is at maximum speed.
Because the cpu usage is nearly sero, i guess the ipmi sensor ist wrong.
It is a ASRock E3C226D2I Board with i3-4160 processor and standard intel CPU-fan.
Any idea whats going wrong here?
thanks so much!
pakka
wow... after 5th reboot now the ipmi shows almost the same cpu temperature of 31°C.
Any idea how to provide that in future? Or has had anyone else seen this before?
pakka
Version 11.1-U1 is mine.
but cpu usage is not the problem i guess. this is under 10%. only the mainboard temperature-sensure failed.
The Aspeed BMCs sometimes get wonky sensor readings. Rebooting them (not the host) tends to solve the problem.
Nick2253
Also, updating the IPMI software helped me. I still get wonky readings, just not as often on the latest software.
omerome
I also have that problem and I never related it to FreeNAS. Same exact ASRock motherboard model. I had to get a board RMA'd because it was happening quite often. Now my replacement has it happen, but less frequently.
pakka
with the newest firmware from asrock and a hard reboot of the ipmi (is there another way to reboot it?) meaning unplug and re-plug it works quite fine for the last days.
cpu-fan increases in case of hard-working and decreases again. so all fine so far.
