I have a Supermicro X10SLM-F with Bios 2.0 and IPMI-Firmware 01.35. When I set the fan mode to "optimal" I get the following sensor outputs:
4 | CPU Temp | Temperature | 36.00 | C | 'OK'
71 | System Temp | Temperature | 29.00 | C | 'OK'
138 | Peripheral Temp | Temperature | 36.00 | C | 'OK'
205 | PCH Temp | Temperature | 49.00 | C | 'OK'
272 | P1-DIMMA1 Temp | Temperature | N/A | C | N/A
339 | P1-DIMMA2 Temp | Temperature | 30.00 | C | 'OK'
406 | P1-DIMMB1 Temp | Temperature | N/A | C | N/A
473 | P1-DIMMB2 Temp | Temperature | 29.00 | C | 'OK'
540 | FAN1 | Fan | 2100.00 | RPM | 'OK'
607 | FAN2 | Fan | 2000.00 | RPM | 'OK'
674 | FAN3 | Fan | 2000.00 | RPM | 'OK'
741 | FAN4 | Fan | 2000.00 | RPM | 'OK'
808 | FANA | Fan | 1200.00 | RPM | 'OK'
Are these really optimal fan speeds for the shown temperatures? I understood that there is no way to directly set the fans' speeds. Is there any other way (besides fan mode) to influence the speeds?
