Fan speed on X10SL7-F
trumee
I have a E5-1231 v3 CPU using a stock heat sink connected to the Fan1 connector of the Supermicro X10SL7-F. I loaded the server to increase cpu temperature however the FAN speed only went from 900 to 1000 RPM. How can i tune the fans to get better cooling or is the stock heatsink not sufficient?
#sysctl -a | grep -i temper
hw.acpi.thermal.tz1.temperature: 29.8C
hw.acpi.thermal.tz0.temperature: 27.8C
dev.cpu.7.temperature: 81.0C
dev.cpu.6.temperature: 80.0C
dev.cpu.5.temperature: 81.0C
dev.cpu.4.temperature: 81.0C
dev.cpu.3.temperature: 86.0C
dev.cpu.2.temperature: 86.0C
dev.cpu.1.temperature: 86.0C
dev.cpu.0.temperature: 86.0C
# ipmitool sensor
CPU Temp  | 86.000  | degrees C  | ok  | 0.000  | 0.000  | 0.000  | 95.000  | 100.000  | 100.000
System Temp  | 50.000  | degrees C  | ok  | -9.000  | -7.000  | -5.000  | 80.000  | 85.000  | 90.000
Peripheral Temp  | 45.000  | degrees C  | ok  | -9.000  | -7.000  | -5.000  | 80.000  | 85.000  | 90.000
PCH Temp  | 62.000  | degrees C  | ok  | -11.000  | -8.000  | -5.000  | 90.000  | 95.000  | 100.000
VRM Temp  | 63.000  | degrees C  | ok  | -9.000  | -7.000  | -5.000  | 95.000  | 100.000  | 105.000
DIMMA1 Temp  | 52.000  | degrees C  | ok  | 1.000  | 2.000  | 4.000  | 80.000  | 85.000  | 90.000
DIMMA2 Temp  | 51.000  | degrees C  | ok  | 1.000  | 2.000  | 4.000  | 80.000  | 85.000  | 90.000
DIMMB1 Temp  | 48.000  | degrees C  | ok  | 1.000  | 2.000  | 4.000  | 80.000  | 85.000  | 90.000
DIMMB2 Temp  | 47.000  | degrees C  | ok  | 1.000  | 2.000  | 4.000  | 80.000  | 85.000  | 90.000
FAN1  | 1000.000  | RPM  | ok  | 300.000  | 500.000  | 700.000  | 25300.000 | 25400.000 | 25500.000
FAN2  | na  |  | na  | na  | na  | na  | na  | na  | na
FAN3  | na  |  | na  | na  | na  | na  | na  | na  | na
FAN4  | 300.000  | RPM  | cr  | 200.000  | 300.000  | 400.000  | 25300.000 | 25400.000 | 25500.000
FANA  | na  |  | na  | na  | na  | na  | na  | na  | na
Vcpu  | 1.800  | Volts  | ok  | 1.242  | 1.260  | 1.395  | 1.899  | 2.088  | 2.106
VDIMM  | 1.327  | Volts  | ok  | 1.096  | 1.124  | 1.201  | 1.642  | 1.719  | 1.747
12V  | 12.051  | Volts  | ok  | 10.164  | 10.521  | 10.776  | 12.918  | 13.224  | 13.224
5VCC  | 5.000  | Volts  | ok  | 4.225  | 4.380  | 4.473  | 5.372  | 5.527  | 5.589
3.3VCC  | 3.329  | Volts  | ok  | 2.804  | 2.894  | 2.969  | 3.554  | 3.659  | 3.689
VBAT  | 3.075  | Volts  | ok  | 2.400  | 2.490  | 2.595  | 3.495  | 3.600  | 3.690
AVCC  | 3.329  | Volts  | ok  | 2.399  | 2.489  | 2.594  | 3.494  | 3.599  | 3.689
VSB  | 3.269  | Volts  | ok  | 2.399  | 2.489  | 2.594  | 3.494  | 3.599  | 3.689
Chassis Intru  | 0x1  | discrete  | 0x0100| na  | na  | na  | na  | na  | na
trumee
I modified the FAN profile in the BIOS to 'full speed' and power cycled the server. Previously it was set to 'Heavy IO'.
Now, I get the same FAN1 speed of ~2000 RPM under both at idle and high load conditions. The good news is that the peak CPU temperature has fallen from 90C to 66C.
Idle conditions
dev.cpu.7.temperature: 38.0C
dev.cpu.6.temperature: 38.0C
dev.cpu.5.temperature: 37.0C
dev.cpu.4.temperature: 37.0C
dev.cpu.3.temperature: 34.0C
dev.cpu.2.temperature: 34.0C
dev.cpu.1.temperature: 44.0C
dev.cpu.0.temperature: 44.0C
# ipmitool sensor
CPU Temp  | 43.000  | degrees C  | ok  | 0.000  | 0.000  | 0.000  | 95.000  | 100.000  | 100.000
System Temp  | 43.000  | degrees C  | ok  | -9.000  | -7.000  | -5.000  | 80.000  | 85.000  | 90.000
Peripheral Temp  | 43.000  | degrees C  | ok  | -9.000  | -7.000  | -5.000  | 80.000  | 85.000  | 90.000
PCH Temp  | 55.000  | degrees C  | ok  | -11.000  | -8.000  | -5.000  | 90.000  | 95.000  | 100.000
VRM Temp  | 42.000  | degrees C  | ok  | -9.000  | -7.000  | -5.000  | 95.000  | 100.000  | 105.000
DIMMA1 Temp  | 36.000  | degrees C  | ok  | 1.000  | 2.000  | 4.000  | 80.000  | 85.000  | 90.000
DIMMA2 Temp  | 37.000  | degrees C  | ok  | 1.000  | 2.000  | 4.000  | 80.000  | 85.000  | 90.000
DIMMB1 Temp  | 37.000  | degrees C  | ok  | 1.000  | 2.000  | 4.000  | 80.000  | 85.000  | 90.000
DIMMB2 Temp  | 36.000  | degrees C  | ok  | 1.000  | 2.000  | 4.000  | 80.000  | 85.000  | 90.000
FAN1  | 2000.000  | RPM  | ok  | 300.000  | 500.000  | 700.000  | 25300.000 | 25400.000 | 25500.000
FAN4  | 1900.000  | RPM  | ok  | 200.000  | 300.000  | 400.000  | 25300.000 | 25400.000 | 25500.000
Vcpu  | 1.809  | Volts  | ok  | 1.242  | 1.260  | 1.395  | 1.899  | 2.088  | 2.106
3.3VCC  | 3.344  | Volts  | ok  | 2.804  | 2.894  | 2.969  | 3.554  | 3.659  | 3.689
VSB  | 3.284  | Volts  | ok  | 2.399  | 2.489  | 2.594  | 3.494  | 3.599  | 3.689
High load
# stress --cpu 8
stress: info: [6073] dispatching hogs: 8 cpu, 0 io, 0 vm, 0 hdd
dev.cpu.7.temperature: 63.0C
dev.cpu.6.temperature: 63.0C
dev.cpu.5.temperature: 62.0C
dev.cpu.4.temperature: 62.0C
dev.cpu.3.temperature: 65.0C
dev.cpu.2.temperature: 65.0C
dev.cpu.1.temperature: 66.0C
dev.cpu.0.temperature: 66.0C
# ipmitool sensor
CPU Temp  | 66.000  | degrees C  | ok  | 0.000  | 0.000  | 0.000  | 95.000  | 100.000  | 100.000
System Temp  | 45.000  | degrees C  | ok  | -9.000  | -7.000  | -5.000  | 80.000  | 85.000  | 90.000
Peripheral Temp  | 44.000  | degrees C  | ok  | -9.000  | -7.000  | -5.000  | 80.000  | 85.000  | 90.000
PCH Temp  | 58.000  | degrees C  | ok  | -11.000  | -8.000  | -5.000  | 90.000  | 95.000  | 100.000
VRM Temp  | 50.000  | degrees C  | ok  | -9.000  | -7.000  | -5.000  | 95.000  | 100.000  | 105.000
DIMMA1 Temp  | 39.000  | degrees C  | ok  | 1.000  | 2.000  | 4.000  | 80.000  | 85.000  | 90.000
DIMMA2 Temp  | 38.000  | degrees C  | ok  | 1.000  | 2.000  | 4.000  | 80.000  | 85.000  | 90.000
DIMMB1 Temp  | 38.000  | degrees C  | ok  | 1.000  | 2.000  | 4.000  | 80.000  | 85.000  | 90.000
DIMMB2 Temp  | 37.000  | degrees C  | ok  | 1.000  | 2.000  | 4.000  | 80.000  | 85.000  | 90.000
FAN1  | 2100.000  | RPM  | ok  | 300.000  | 500.000  | 700.000  | 25300.000 | 25400.000 | 25500.000
FAN4  | 2000.000  | RPM  | ok  | 200.000  | 300.000  | 400.000  | 25300.000 | 25400.000 | 25500.000
Vcpu  | 1.791  | Volts  | ok  | 1.242  | 1.260  | 1.395  | 1.899  | 2.088  | 2.106
VDIMM  | 1.320  | Volts  | ok  | 1.096  | 1.124  | 1.201  | 1.642  | 1.719  | 1.747
TXAG26
I've never been impressed with the stock heatsinks. I've been happy with the Noctua brand heatsinks. Even with 50-60% cpu utilization, I rarely see temperatures above 36-40c. Room temp is about 75F. The Noctua NH-U9S fits well on your board and uses 92mm fans.
depasseg
FreeNAS Replicant
Heat sink and heat transfer paste might not be installed properly.
trumee
What peak temperature do you get with this cooler on X10SL7-F with 100% CPU?
TXAG26
I don't recall, but I have a E3-1245 v3 with the same Noctua heatsink also on a Supermicro X10 board that is being used as a workstation. I'll try to fire up an instance of CPU burn this evening to see how high it gets. In the interim, do a search for reviews for the Noctua NH-U9S or NH-U9B (they're the same heatsink) compared against the stock heatsink. I do recall the paste that Intel used to include on the boxed heatsinks was not the best. You could probably get things down a few more degrees by scraping that stuff off and applying a high quality compound like AS5 or similar.
The only major problem with the stock heatsink is that the installation process does not give good feedback as to whether it is securely in place or not.
Actually, it was very good, in part because it was applied just right for best results.
