SOLVED Loud Noctua PWM Fans
Mark Francis
Hello all,
I have recently built a personal FreeNAS build based on the recommendations in the pinned threads. The highlights are:
Supermicro X10SL7-F
Noctua NF-F12PWM Case Fan 120 mm
Based on this[1]- thread I have set my fan mode to optimal:
ipmitool raw 0x30 0x45 0x1 0x0 (Set Mode to Standard)
ipmitool raw 0x30 0x45 0x1 0x1 (Set Mode to Full)
ipmitool raw 0x30 0x45 0x1 0x2 (Set Mode to Optimal)
ipmitool raw 0x30 0x45 0x1 0x4 (Set Mode to Heavy I/O)
ipmitool raw 0x30 0x45 0x0 (Get Fan Mode)
[root@freenas ~]# ipmitool raw 0x30 0x45 0x0
 02
I have also set the sensor thresholds as mentioned:
ipmitool sensor thresh "FANA" upper 1700 1900 2100
ipmitool sensor thresh "FANA" lower 200 300 400
ipmitool sensor thresh "FAN2" upper 1700 1900 2100
ipmitool sensor thresh "FAN2" lower 200 300 400
ipmitool sensor thresh "FAN3" upper 1700 1900 2100
ipmitool sensor thresh "FAN3" lower 200 300 400
ipmitool sensor thresh "FAN4" upper 1700 1900 2100
ipmitool sensor thresh "FAN4" lower 200 300 400
...which can be seen here:
[root@freenas ~]# ipmitool sensor list all
CPU Temp		 | 29.000	 | degrees C  | ok	| 0.000	 | 0.000	 | 0.000	 | 95.000	| 100.000   | 100.000
System Temp	  | 57.000	 | degrees C  | ok	| -9.000	| -7.000	| -5.000	| 80.000	| 85.000	| 90.000
Peripheral Temp  | 41.000	 | degrees C  | ok	| -9.000	| -7.000	| -5.000	| 80.000	| 85.000	| 90.000
PCH Temp		 | 53.000	 | degrees C  | ok	| -11.000   | -8.000	| -5.000	| 90.000	| 95.000	| 100.000
VRM Temp		 | 36.000	 | degrees C  | ok	| -9.000	| -7.000	| -5.000	| 95.000	| 100.000   | 105.000
DIMMA1 Temp	  | 28.000	 | degrees C  | ok	| 1.000	 | 2.000	 | 4.000	 | 80.000	| 85.000	| 90.000
DIMMA2 Temp	  | na		 |			| na	| na		| na		| na		| na		| na		| na
DIMMB1 Temp	  | 28.000	 | degrees C  | ok	| 1.000	 | 2.000	 | 4.000	 | 80.000	| 85.000	| 90.000
DIMMB2 Temp	  | na		 |			| na	| na		| na		| na		| na		| na		| na
FAN1			 | na		 |			| na	| na		| na		| na		| na		| na		| na
FAN2			 | na		 |			| na	| na		| na		| na		| na		| na		| na
FAN3			 | 1100.000   | RPM		| ok	| 200.000   | 300.000   | 400.000   | 1700.000  | 1900.000  | 2100.000
FAN4			 | na		 |			| na	| na		| na		| na		| na		| na		| na
FANA			 | 1500.000   | RPM		| ok	| 200.000   | 300.000   | 400.000   | 1700.000  | 1900.000  | 2100.000
Vcpu			 | 1.773	  | Volts	  | ok	| 1.242	 | 1.260	 | 1.395	 | 1.899	 | 2.088	 | 2.106
VDIMM			| 1.327	  | Volts	  | ok	| 1.096	 | 1.124	 | 1.201	 | 1.642	 | 1.719	 | 1.747
12V			  | 12.000	 | Volts	  | ok	| 10.164	| 10.521	| 10.776	| 12.918	| 13.224	| 13.224
5VCC			 | 4.969	  | Volts	  | ok	| 4.225	 | 4.380	 | 4.473	 | 5.372	 | 5.527	 | 5.589
3.3VCC		   | 3.299	  | Volts	  | ok	| 2.804	 | 2.894	 | 2.969	 | 3.554	 | 3.659	 | 3.689
VBAT			 | 2.985	  | Volts	  | ok	| 2.400	 | 2.490	 | 2.595	 | 3.495	 | 3.600	 | 3.690
AVCC			 | 3.284	  | Volts	  | ok	| 2.399	 | 2.489	 | 2.594	 | 3.494	 | 3.599	 | 3.689
VSB			  | 3.269	  | Volts	  | ok	| 2.399	 | 2.489	 | 2.594	 | 3.494	 | 3.599	 | 3.689
Chassis Intru	| 0x1		| discrete   | 0x0100| na		| na		| na		| na		| na		| na
As you can see I have FAN3 and FANA in use.
QUESTION: Can anyone explain why the Noctua NF-F12PWM is so much louder than the default case fans I have (Fractal silent series R2).
[1] https://forums.freenas.org/index.php?threads/thermal-and-accoustical-design-validation.28364/
Regular NF-F12s? Loud? I have a whole bunch of IndustrialPPC3000 PWM fans in several computers here, and they're essentially inaudible when being controlled.
Mark Francis
So I did some digging, as noted here: https://forums.freenas.org/index.ph...-fan-zone-controller.46159/page-4#post-327841
I don't think many people check that thread, so I'm going to return to this one.
Using the above suggested script, the fans initially slow down and go inaudible, then at aprox 12 seconds into the execution of the script, they spin back up to full, with nothing being logged by the script.
2016-11-27 16:10:08: Setting fan mode to 1 (full)
2016-11-27 16:10:13: CPU Temp: 27.0
2016-11-27 16:10:13: CPU Temp: 27.0 <= 35, CPU Fan going low.
2016-11-27 16:10:13: CPU Fan: low
2016-11-27 16:10:13: CPU Fan changing... (low)
2016-11-27 16:10:13: Setting Zone 0 duty cycle to 40%
2016-11-27 16:10:13: /dev/ada1: 24
2016-11-27 16:10:13: Maximum HD Temperature: 24
2016-11-27 16:10:13: Drives are cool enough, going to 40%
2016-11-27 16:10:13: Setting Zone 1 duty cycle to 40%
2016-11-27 16:10:14: CPU Temp: 27.0
2016-11-27 16:10:14: CPU Fan: low
2016-11-27 16:10:15: CPU Temp: 28.0
2016-11-27 16:10:15: CPU Fan: low
2016-11-27 16:10:16: CPU Temp: 27.0
2016-11-27 16:10:16: CPU Fan: low
2016-11-27 16:10:17: CPU Temp: 27.0
2016-11-27 16:10:17: CPU Fan: low
2016-11-27 16:10:18: CPU Temp: 27.0
2016-11-27 16:10:18: CPU Fan: low
2016-11-27 16:10:19: CPU Temp: 27.0
2016-11-27 16:10:19: CPU Fan: low
2016-11-27 16:10:20: CPU Temp: 27.0
2016-11-27 16:10:20: CPU Fan: low
These are my fan thresholds (taken from https://forums.freenas.org/index.ph...or-thresholds-with-ipmi-using-ipmitool.23571/) :
CPU Temp		 | 28.000	 | degrees C  | ok	| 0.000	 | 0.000	 | 0.000	 | 95.000	| 100.000   | 100.000
System Temp	  | 39.000	 | degrees C  | ok	| -9.000	| -7.000	| -5.000	| 80.000	| 85.000	| 90.000
Peripheral Temp  | 37.000	 | degrees C  | ok	| -9.000	| -7.000	| -5.000	| 80.000	| 85.000	| 90.000
FAN3			 | 1400.000   | RPM		| ok	| 400.000   | 500.000   | 600.000   | 3700.000  | 3800.000  | 3900.000
FAN4			 | 1500.000   | RPM		| ok	| 400.000   | 500.000   | 600.000   | 3700.000  | 3800.000  | 3900.000
FANA			 | 1100.000   | RPM		| ok	| 400.000   | 500.000   | 600.000   | 3700.000  | 3800.000  | 3900.000
Assuming the first column is the actual current fan speed, I can see it drops to about 500 and then spins back up high, as shown below:
[root@freenas] ~# ipmitool sensor list all | grep FAN
FAN3			 | 600.000	| RPM		| nc	| 400.000   | 500.000   | 600.000   | 3700.000  | 3800.000  | 3900.000
FAN4			 | 600.000	| RPM		| nc	| 400.000   | 500.000   | 600.000   | 3700.000  | 3800.000  | 3900.000
FANA			 | 500.000	| RPM		| cr	| 400.000   | 500.000   | 600.000   | 3700.000  | 3800.000  | 3900.000
FAN3			 | 1300.000   | RPM		| ok	| 400.000   | 500.000   | 600.000   | 3700.000  | 3800.000  | 3900.000
FAN4			 | 1400.000   | RPM		| ok	| 400.000   | 500.000   | 600.000   | 3700.000  | 3800.000  | 3900.000
FANA			 | 1000.000   | RPM		| ok	| 400.000   | 500.000   | 600.000   | 3700.000  | 3800.000  | 3900.000
I'm wondering if the fans are hitting the Lower Non-Recoverable or Lower Critical thresholds and the system panics and spins then to full.
Any help would be greatly appreciated.
So drop them.
Stux
Certainly happens in my system. I have my lnr /cr set to zero. Which prevents it.
Thought I posted this somewhere :-/
Stux
And FANA isn't affected by Optimal.
My script is the right solution, although it might need 'improving' for your system.
