ricky_198
- Jan 1, 2015
System Info:
FreeNAS version: FreeNAS-9.10-STABLE-201605240427
Case: Fractal Design Node-804
Motherboard: Supermicro X10SL7-F
CPU: Intel(R) Xeon(R) CPU E3-1230 v3 @ 3.30GHz
RAM Size: 32GB/Crucial CT2KIT102472BD160B
PSU: 450w-Seasonic-G-Series
My case is fitted with 8 x Silent Series R2 120mm case fans. My CPU stock fan is connected to FAN1.
The remainder of the fans are connected by Akasa fan splitter's which connects 2 of the fans to one fan header on the motherboard from FAN2, FAN 3, FAN4 and FANA.
I have followed the "Supermicro-X10-X11-Motherboard-Faq" thread along with reading the 2 dedicated threads on this subject. I have therefore adjusted my fan thresholds to more reasonable values.
Even after re-starting the server, power cycling, resetting the BMC, re-flashing the Management Engine, the RPM of the fans still jump from 1200 to almost double and insane values the values (2300 R.P.M/4800 R.P.M).
I've set the fan speeds via the webgui to optimal, standard and full speeds as well as made sure I have latest BIOS and IPMI firmware to the latest firmware. Still the same problem occurs.
I'm really not sure what else I can try to stop the RPM jumping. Not sure if it's the fans themselves, or a setting I've overlooked. Would really appreciate any help.
CPU Temp | 32.000 | degrees C | ok | 0.000 | 0.000 | 0.000 | 95.000 | 100.000 | 100.000 System Temp | 35.000 | degrees C | ok | -9.000 | -7.000 | -5.000 | 80.000 | 85.000 | 90.000 Peripheral Temp | 37.000 | degrees C | ok | -9.000 | -7.000 | -5.000 | 80.000 | 85.000 | 90.000 PCH Temp | 41.000 | degrees C | ok | -11.000 | -8.000 | -5.000 | 90.000 | 95.000 | 100.000 VRM Temp | 34.000 | degrees C | ok | -9.000 | -7.000 | -5.000 | 95.000 | 100.000 | 105.000 DIMMA1 Temp | 29.000 | degrees C | ok | 1.000 | 2.000 | 4.000 | 80.000 | 85.000 | 90.000 DIMMA2 Temp | 30.000 | degrees C | ok | 1.000 | 2.000 | 4.000 | 80.000 | 85.000 | 90.000 DIMMB1 Temp | 29.000 | degrees C | ok | 1.000 | 2.000 | 4.000 | 80.000 | 85.000 | 90.000 DIMMB2 Temp | 28.000 | degrees C | ok | 1.000 | 2.000 | 4.000 | 80.000 | 85.000 | 90.000 FAN1 | 2000.000 | RPM | ok | 100.000 | 200.000 | 300.000 | 2500.000 | 2600.000 | 2700.000 FAN2 | 1200.000 | RPM | nc | 100.000 | 200.000 | 300.000 | 1200.000 | 1300.000 | 1400.000 FAN3 | 1200.000 | RPM | ok | 100.000 | 200.000 | 300.000 | 1200.000 | 1300.000 | 1400.000 FAN4 | 1200.000 | RPM | nc | 100.000 | 200.000 | 300.000 | 1200.000 | 1300.000 | 1400.000 FANA | 1200.000 | RPM | nc | 100.000 | 200.000 | 300.000 | 1200.000 | 1300.000 | 1400.000 Vcpu | 1.791 | Volts | ok | 1.242 | 1.260 | 1.395 | 1.899 | 2.088 | 2.106 VDIMM | 1.320 | Volts | ok | 1.096 | 1.124 | 1.201 | 1.642 | 1.719 | 1.747 12V | 11.949 | Volts | ok | 10.164 | 10.521 | 10.776 | 12.918 | 13.224 | 13.224 5VCC | 5.000 | Volts | ok | 4.225 | 4.380 | 4.473 | 5.372 | 5.527 | 5.589 3.3VCC | 3.329 | Volts | ok | 2.804 | 2.894 | 2.969 | 3.554 | 3.659 | 3.689 VBAT | 2.970 | Volts | ok | 2.400 | 2.490 | 2.595 | 3.495 | 3.600 | 3.690 AVCC | 3.329 | Volts | ok | 2.399 | 2.489 | 2.594 | 3.494 | 3.599 | 3.689 VSB | 3.269 | Volts | ok | 2.399 | 2.489 | 2.594 | 3.494 | 3.599 | 3.689 Chassis Intru | 0x0 | discrete | 0x0000| na | na | na | na | na | na
