Jeff Lamer
- Nov 17, 2015
Hey All,
Had this problem for awhile now. Occasionally I hear my fans pulsing high to low. Not sure what to do to fix? All temps look good.
root@freenas:~ # ipmitool sensor list all
CPU Temp | 36.000 | degrees C | ok | 0.000 | 0.000 | 0.0 00 | 95.000 | 100.000 | 100.000
System Temp | 44.000 | degrees C | ok | -9.000 | -7.000 | -5. 000 | 80.000 | 85.000 | 90.000
Peripheral Temp | 39.000 | degrees C | ok | -9.000 | -7.000 | -5. 000 | 80.000 | 85.000 | 90.000
PCH Temp | 48.000 | degrees C | ok | -11.000 | -8.000 | -5. 000 | 90.000 | 95.000 | 100.000
VRM Temp | 37.000 | degrees C | ok | -9.000 | -7.000 | -5. 000 | 95.000 | 100.000 | 105.000
DIMMA1 Temp | 30.000 | degrees C | ok | 1.000 | 2.000 | 4.0 00 | 80.000 | 85.000 | 90.000
DIMMA2 Temp | na | | na | na | na | na | na | na | na
DIMMB1 Temp | 29.000 | degrees C | ok | 1.000 | 2.000 | 4.0 00 | 80.000 | 85.000 | 90.000
DIMMB2 Temp | na | | na | na | na | na | na | na | na
FAN1 | 600.000 | RPM | nc | 300.000 | 500.000 | 700 .000 | 25300.000 | 25400.000 | 25500.000
FAN2 | na | | na | na | na | na | na | na | na
FAN3 | na | | na | na | na | na | na | na | na
FAN4 | 500.000 | RPM | cr | 300.000 | 500.000 | 700 .000 | 25300.000 | 25400.000 | 25500.000
FANA | 1000.000 | RPM | ok | 300.000 | 500.000 | 700 .000 | 25300.000 | 25400.000 | 25500.000
Vcpu | 1.755 | Volts | ok | 1.242 | 1.260 | 1.3 95 | 1.899 | 2.088 | 2.106
VDIMM | 1.453 | Volts | ok | 1.096 | 1.124 | 1.2 01 | 1.642 | 1.719 | 1.747
12V | 12.000 | Volts | ok | 10.164 | 10.521 | 10. 776 | 12.918 | 13.224 | 13.224
5VCC | 4.969 | Volts | ok | 4.225 | 4.380 | 4.4 73 | 5.372 | 5.527 | 5.589
3.3VCC | 3.314 | Volts | ok | 2.804 | 2.894 | 2.9 69 | 3.554 | 3.659 | 3.689
VBAT | 3.045 | Volts | ok | 2.400 | 2.490 | 2.5 95 | 3.495 | 3.600 | 3.690
AVCC | 3.314 | Volts | ok | 2.399 | 2.489 | 2.5 94 | 3.494 | 3.599 | 3.689
VSB | 3.269 | Volts | ok | 2.399 | 2.489 | 2.5 94 | 3.494 | 3.599 | 3.689
Chassis Intru | 0x0 | discrete | 0x0000| na | na | na | na | na | na
Jeff
Jeff
