Hi folks,
I'm having a heck of a time slowing down the fans on my new FreeNAS build. Initially they were spooling up and down every few seconds, so I searched and found these threads, then used ipmitool to set some appropriate thresholds and selected "optimal" fan mode.
This stopped the spooling up & down behavior but unfortunately seems to have fixed the fans at 100% duty cycle. I have tried all 4 fan modes and none of them make any difference. When changing modes the fans do spin down for a moment, then jump back up to 100% and stay there.
Any help would be greatly appreciated!
Configuration:
Supermicro X11SSL-CF motherboard
(1) Generic CPU fan (came with my E3-1240 V6 CPU) connected to FAN1
(4) Fractal Design Venturi HP FDB PWM case fans connected to FAN2, FAN3, FAN4 and FANA
Commands I've issued:
Current sensor list:
Everything has been left at the defaults with the exception of the fan thresholds.
Thank you in advance for any assistance you can provide!
Configuration:
ipmitool sensor thresh "FAN1" lower 300 500 700 ipmitool sensor thresh "FAN2" lower 200 300 400 ipmitool sensor thresh "FAN3" lower 200 300 400 ipmitool sensor thresh "FAN4" lower 200 300 400 ipmitool sensor thresh "FANA" lower 200 300 400 ipmitool sensor thresh "FAN1" upper 3200 3500 3800 ipmitool sensor thresh "FAN2" upper 1900 2000 2100 ipmitool sensor thresh "FAN3" upper 1900 2000 2100 ipmitool sensor thresh "FAN4" upper 1900 2000 2100 ipmitool sensor thresh "FANA" upper 1900 2000 2100 ipmitool raw 0x30 0x45 0x1 0x2
CPU Temp | 33.000 | degrees C | ok | 0.000 | 0.000 | 0.000 | 95.000 | 100.000 | 100.000 PCH Temp | 31.000 | degrees C | ok | 0.000 | 5.000 | 16.000 | 90.000 | 95.000 | 100.000 System Temp | 34.000 | degrees C | ok | -10.000 | -5.000 | 0.000 | 80.000 | 85.000 | 90.000 Peripheral Temp | 37.000 | degrees C | ok | -10.000 | -5.000 | 0.000 | 80.000 | 85.000 | 90.000 VcpuVRM Temp | 30.000 | degrees C | ok | -5.000 | 0.000 | 5.000 | 95.000 | 100.000 | 105.000 DIMMA1 Temp | na | | na | na | na | na | na | na | na DIMMA2 Temp | 28.000 | degrees C | ok | -5.000 | 0.000 | 5.000 | 80.000 | 85.000 | 90.000 DIMMB1 Temp | na | | na | na | na | na | na | na | na DIMMB2 Temp | 27.000 | degrees C | ok | -5.000 | 0.000 | 5.000 | 80.000 | 85.000 | 90.000 FAN1 | 3100.000 | RPM | ok | 300.000 | 500.000 | 700.000 | 3200.000 | 3500.000 | 3800.000 FAN2 | 1700.000 | RPM | ok | 200.000 | 300.000 | 400.000 | 1900.000 | 2000.000 | 2100.000 FAN3 | 1700.000 | RPM | ok | 200.000 | 300.000 | 400.000 | 1900.000 | 2000.000 | 2100.000 FAN4 | 1800.000 | RPM | ok | 200.000 | 300.000 | 400.000 | 1900.000 | 2000.000 | 2100.000 FANA | 1700.000 | RPM | ok | 200.000 | 300.000 | 400.000 | 1900.000 | 2000.000 | 2100.000 12V | 12.128 | Volts | ok | 10.144 | 10.272 | 10.784 | 12.960 | 13.280 | 13.408 5VCC | 4.948 | Volts | ok | 4.246 | 4.298 | 4.480 | 5.390 | 5.546 | 5.598 3.3VCC | 3.333 | Volts | ok | 2.789 | 2.823 | 2.959 | 3.554 | 3.656 | 3.690 VBAT | 2.972 | Volts | ok | 2.384 | 2.496 | 2.580 | 3.476 | 3.588 | 3.672 Vcpu | 0.796 | Volts | ok | 0.085 | 0.085 | 0.085 | 1.588 | 1.750 | 1.768 VDIMMAB | 1.200 | Volts | ok | 0.948 | 0.975 | 1.047 | 1.344 | 1.425 | 1.443 5VSB | 5.026 | Volts | ok | 4.246 | 4.376 | 4.480 | 5.390 | 5.546 | 5.598 3.3VSB | 3.265 | Volts | ok | 2.755 | 2.840 | 2.908 | 3.503 | 3.605 | 3.639 VPCH 1.5V | 1.050 | Volts | ok | 0.825 | 0.852 | 0.915 | 1.176 | 1.239 | 1.266 Chassis Intru | 0x0 | discrete | 0x0000| na | na | na | na | na | na
