CPU fan speed "stuck"
Cougar014
I'm having a problem with my CPU cooler.
At first i thought that my CPU fan was just nice en quiet, but after i while i found out that no matter how hard i use my system, the CPU fan is just always stuck @1000RPM.
The cpu temp runs up to 74 degree C (~165 F) after some heavy stress testing (after about half an hour) and the CPU fan just stays idle....
When my system is idle, the temperature just floats somewhere around the 26 degree C (78 F)
However,
When i boot up my system, the CPU fan makes more noise for the time it runs through it BIOS, after that it idles @1000RPM and it just stays there.
When i log into IPMI i can change the fan mode of my system to 4 different modes (standard, full speed, optimal, heavyIO mode) the CPU fan does respond to this input, but the problem is
that these are fixed speeds and i want it (offcourse) to be temperature regulated.
(it is currently set to the optimal fan mode with a speed of 1000RPM).
This is my hardware:
Intel XEON 1240v5 CPU
Stock intel CPU cooler
Supermicro X11SSL-cf Motherboard
I have the CPU fan connected to the FANA header, just as the manual says.
Also i cant find anything in the bios related to fan speeds. But maybe i am looking over it.
I hope someone here has some suggestions.
Thanks in advance!
Cougar014
The manual is wrong. Use one of the other headers.
Hey, Thanks for your answer.
I have change it to another header.
And it indeed works beter.
Right now the CPU fan floats between 1000-1500 RPM.
And the temperature doesn't goes beyond 60 degree C. (@60 the RPM goes from 1400 to 1500, then it stops climbing).
I find the temperature a bit high though, with a fan speed that low.
Is there a way to change it? Or are they all fixed speeds?
Or do I have to change the cooler in order to get beter performance?
Thanks in advance
