Ubiquiti Unifi Controller on FreeNAS
c77dk
you can run it just fine - in a jail or vm. I ended up just using a vm myself
Netdewt
I'll be running on an Atom E3940 with 8GB RAM. Would either of those be less taxing to the system?
c77dk
with that amount of ram I would try the jail - with vm you generally use more memory. 8GB is the minimum for TrueNAS - are you able to put more ram into the system?
If this is not a good solution, I would just get the Unifi dongle I guess. Or Raspberry Pi but that seems like more fiddling for something that's not any cheaper. I'm frustrated with running the controller on my workstation.
A jail should be fine, but keep an eye on performance of the other NAS functions you're using.
To help, there is a community plugin for it, maybe try that as a start.
Jailer
Not strong, but bad
It's super easy to install in a jail. Create a standard jail and run pkg install unifi5 followed by sysrc "unifi_enable=YES" and then service unifi start and you're up and running.
kiriak
I have Unifi Controller running on a jail, I just used the plug-in.
It is on an old PC with 6 Gb RAM
(with the sole purpose for me to become familiar with TrueNAS before moving to proper hardware).
If I stop the Unifi jail, the RAM used be services is lowered by 400-500 Mb,
so we could assume that this is the impact on RAM ?
There is almost no impact on CPU, as CPU usage (for the whole system) is between 0 and 1% (on an old i3).
Netdewt
Great insight thank you.
This NAS is also for me to learn with, but I also don't want to lose my data. I'll use it as a home server for tax documents and family pictures. 4x4TB HGST Deskstar NAS drives in mirrored vdevs.
Jailer
Not strong, but bad
Yes, pretty typical for a database on memory usage.
The only problem I had was the version of the UniFi controller provided as a plug-in didn't update regularly. I went back to the UniFi controller on in an ESXi VM....
Netdewt
So with the plug-in, you can't force an update?
Can you create a jail and not use the plug-in in some way to get the most up to date version?
Jailer
Not strong, but bad
Netdewt
Right, but N.R said it doesn't update very well. I'm sure I misunderstand all these terms.
Patrick M. Hausen
SweetAndLow
Sweet'NASty
Since this is a new install it might be better to install unifi6 instead of 5. That way you don't have to migrate to 6 eventually.
Netdewt
Yeah, I have the site currently set up on 6, controller running on Mac OS. I haven't looked into the details but I assume you can move a site to a different controller.
Jailer
Not strong, but bad
Unifi6 is not available as a package. If you want it you'll have to install the port and I wouldn't recommend that to most new users without an installation guide to follow.
Another option would be to set up a docker host (yes, more work) and use the jacobalbery container. He (I'm assuming a "he" - "jacob") seems quite good at keeping the container up to date.
Netdewt
I’m open to trying something more difficult as long as I have a strategy to go back. I just dealt with a big headache re-adopting hardware from an old controller I didn’t have access to anymore. In hindsight it was a simple problem, but it was hard to find the solution (USG had to be updated before it would adopt).
It looks like I have to be on 6 if I don’t want to go through that whole process again.
