Wizened Sage
- Aug 16, 2011
.29 is also the latest version released for the Cloud Key, or available on the Unifi download page..29 is the most current version of the FreeBSD port
As 5.9 is greater than 5.6, I'd have to agree.seems the .29 is the latest
same here .. ran into my first kinda of hassle though with my UniFi AP's not upgrading through the controller software and had to use WinSCP and Putty to SSH into each of them and manually update their firmware. Last couple updates upgraded just fine so I don't know what the deal was/is on this latest firmware upgrade.For what it's worth I have been running the UniFi controller in a jail for nearly a month and no problems, it works well.
service unifi stop
root@unifi:/usr/ports/net-mgmt/unifi5 # make reinstall clean ===> Installing for unifi5-5.9.29_1 ===> Registering installation for unifi5-5.9.29_1 *** Error code 70 Stop. make[1]: stopped in /usr/ports/net-mgmt/unifi5 *** Error code 1 Stop. make: stopped in /usr/ports/net-mgmt/unifi5 root@unifi:/usr/ports/net-mgmt/unifi5 #
Likely not since the latest available version in the repo is 5.9.29_1.has anybody of you tried to update the controller to 5.10.12?
root@unifi:/usr/ports/net-mgmt/unifi5 # make reinstall clean ===> unifi5-5.10.19 depends on file: /usr/local/sbin/pkg - found => unifi_sysvinit_all.deb doesn't seem to exist in /usr/ports/distfiles/unifi5-5.10.19. => Attempting to fetch http://dl.ubnt.com/unifi/5.10.19/unifi_sysvinit_all.deb unifi_sysvinit_all.deb 100% of 77 MB 5758 kBps 00m14s ===> Fetching all distfiles required by unifi5-5.10.19 for building ===> Extracting for unifi5-5.10.19 => SHA256 Checksum OK for unifi5-5.10.19/unifi_sysvinit_all.deb. ===> Patching for unifi5-5.10.19 (cd /usr/ports/net-mgmt/unifi5/work/unifi5-5.10.19/usr/lib/unifi/lib && /bin/ln-f -s /usr/local/share/java/classes/snappy-java.jar snappy-java-*.jar) /bin/rm -f -r /usr/ports/net-mgmt/unifi5/work/unifi5-5.10.19/usr/lib/unifi/lib/native ===> Configuring for unifi5-5.10.19 ===> Staging for unifi5-5.10.19 ===> unifi5-5.10.19 depends on package: mongodb36>0 - found ===> unifi5-5.10.19 depends on package: snappyjava>0 - found ===> unifi5-5.10.19 depends on file: /usr/local/openjdk8/bin/java - found ===> Generating temporary packing list ===> Creating groups. ===> Creating users /bin/mkdir -p /usr/ports/net-mgmt/unifi5/work/stage/usr/local/share/java/unifi (cd /usr/ports/net-mgmt/unifi5/work/unifi5-5.10.19/usr/lib/unifi && /bin/sh -c '(/usr/bin/find -Ed $1 $3 | /usr/bin/cpio -dumpl $2 >/dev/null 2>&1) && /usr/bin/find -Ed $1 $3 \( -type d -exec /bin/sh -c '\''cd '\''$2'\'' && chmod 755 "$@"'\'' . {} + -o -type f -exec /bin/sh -c '\''cd '\''$2'\'' && chmod 0644 "$@"'\'' . {} + \)' COPYTREE_SHARE \* /usr/ports/net-mgmt/unifi5/work/stage/usr/local/share/java/unifi/) /bin/ln -sf /usr/local/bin/mongod /usr/ports/net-mgmt/unifi5/work/stage/usr/local/share/java/unifi/bin/mongod /bin/mkdir -p /usr/ports/net-mgmt/unifi5/work/stage//usr/local/share/java/unifi/data /bin/mkdir -p /usr/ports/net-mgmt/unifi5/work/stage//usr/local/share/java/unifi/logs /bin/mkdir -p /usr/ports/net-mgmt/unifi5/work/stage//usr/local/share/java/unifi/run /bin/mkdir -p /usr/ports/net-mgmt/unifi5/work/stage//usr/local/share/java/unifi/work ====> Compressing man pages (compress-man) ===> Staging rc.d startup script(s) ===> Installing for unifi5-5.10.19 ===> Registering installation for unifi5-5.10.19 *** Error code 70 Stop. make[1]: stopped in /usr/ports/net-mgmt/unifi5 *** Error code 1 Stop. make: stopped in /usr/ports/net-mgmt/unifi5 root@unifi:/usr/ports/net-mgmt/unifi5 # service unifi start Starting unifi. root@unifi:/usr/ports/net-mgmt/unifi5 #
make deinstall reinstall all clean
pkg update pkg install unifi5 sysrc unifi_enable=YES service unifi start
pkg upgrade
Already changed that to fetch the latest.By default the jails now follow the quarterly release branch. You could change it to the latest branch, or wait until April for the update to reach the quarterly branch.
