- Jul 2, 2019
Hi Folks - I have my UniFi controller running in a FreeBSD jail on my FreeNAS machine (11.2-U7). The install followed the CEOS3C instructions found at Install UniFi Controller on FreeNAS 11.2-U5 - Quick & Easy.
I have had UniFi running without issues for about two months. For some reason last night the UniFi services stopped running and will not restart. The jail is up and running but the web server refuses to start. I can access the jail using
I tried to manually start UniFi in the jail with:
(I don't think I needed the
There was no update to the jail that I can see.
(I do have recent backups (downloaded) but I was doing a number of changes over the past few days and, hitting-head-with-a-hammer, did not back the most recent configs. Is there any way to download the configs from the APs and switches before re-installing the UniFi controller?)
Does anyone have any suggestions?
Thanks!
Mike
jexec <#> /bin/csh
(# being the appropriate jail number). I can also ping out of the jail to the router, switches, etc. The jail is also ping-able from a workstation.I tried to manually start UniFi in the jail with:
sysrc unifi_enable=YES
service unifi start
but I used it anyway)There was no update to the jail that I can see.
Thanks!
Mike
