Little over my head. Hoping to get Unifi Controller installed in FreeNAS.
Huib
You probably are root.
If you are don't use sudo. It will not be found.
I've made a fresh jail for testing and then I did this:
pkg update
pkg upgrade
portsnap fetch update #this gives an error. Extract portsnap first
portsnap extract
portsnap fetch update #portsnap is up to date.
cd /usr/ports
make search name=unifi5 #it is found
cd /usr/ports/net-mgmt/unifi5
#this is where I stopped. I might try to "make" it when I get home.
#The rest would be
make config-recursive
make install
sysrc unifi_enable=YES
service unifi start
-RYknow
pkg update
pkg upgrade
portsnap extract
cd /usr/ports
make search unifi5 #it is found
#The rest would be
make install
service unifi start
So at this point, and I better to just nuke the jail I created and start from scratch? I might just wait till you proceed all the way through, just want to make sure it's going to work.
-RYknow
Huib
so wait a few hours.
I'll see if it installes correctly after this procedure (finishes without errors)
but as you know that takes a while.
-RYknow
Ohh yeah. I'm going to sit tight. I'm at work and can't touch it till I get home later tonight anyway. =]
I appreciate the time your putting into though! Thank you sir! :)
Huib
Unfortunately it didn't work.
gmake[11]: *** No rule to make target '/usr/ports/java/openjdk8/work/openjdk/hotspot/src/cpu/amd64/vm/x86_64.ad', needed by '../generated/adfiles/bsd_x86_64.ad'.  Stop.
gmake[11]: Leaving directory '/usr/ports/java/openjdk8/work/openjdk/build/bsd-x86_64-normal-server-release/hotspot/bsd_amd64_compiler2/product'
gmake[11]: *** Waiting for unfinished jobs....
gmake[10]: *** [/usr/ports/java/openjdk8/work/openjdk/hotspot/make/bsd/makefiles/top.make:91: ad_stuff] Error 2
gmake[10]: Leaving directory '/usr/ports/java/openjdk8/work/openjdk/build/bsd-x86_64-normal-server-release/hotspot/bsd_amd64_compiler2/product'
gmake[9]: *** [/usr/ports/java/openjdk8/work/openjdk/hotspot/make/bsd/Makefile:294: product] Error 2
gmake[9]: Leaving directory '/usr/ports/java/openjdk8/work/openjdk/build/bsd-x86_64-normal-server-release/hotspot'
gmake[8]: *** [Makefile:231: generic_build2] Error 2
gmake[8]: Leaving directory '/usr/ports/java/openjdk8/work/openjdk/hotspot/make'
gmake[7]: *** [Makefile:177: product] Error 2
gmake[7]: Leaving directory '/usr/ports/java/openjdk8/work/openjdk/hotspot/make'
gmake[6]: *** [HotspotWrapper.gmk:45: /usr/ports/java/openjdk8/work/openjdk/build/bsd-x86_64-normal-server-release/hotspot/_hotspot.timestamp] Error 2
gmake[6]: Leaving directory '/usr/ports/java/openjdk8/work/openjdk/make'
gmake[5]: *** [/usr/ports/java/openjdk8/work/openjdk//make/Main.gmk:113: hotspot-only] Error 2
gmake[5]: Leaving directory '/usr/ports/java/openjdk8/work/openjdk'
===> Compilation failed unexpectedly.
Try to set MAKE_JOBS_UNSAFE=yes and rebuild before reporting the failure to
the maintainer.
*** Error code 1
Stop.
make[4]: stopped in /usr/ports/java/openjdk8
*** Error code 1
Stop.
make[3]: stopped in /usr/ports/java/openjdk8
*** Error code 1
Stop.
make[2]: stopped in /usr/ports/devel/maven3
*** Error code 1
Stop.
make[1]: stopped in /usr/ports/archivers/snappy-java
*** Error code 1
Stop.
make: stopped in /usr/ports/net-mgmt/unifi5
at least I saved you some time testing this idea....
-RYknow
the maintainer.
*** Error code 1
Stop.
*** Error code 1
Stop.
*** Error code 1
Stop.
*** Error code 1
Stop.
*** Error code 1
Stop.
Bummer! Sucks it didn't work out. Thanks again for your time though man. I do appreciate it!
-RYknow
maxbet
I have installed UniFi controller in two FreeNAS machines (latests FreeNAS 9.10.2-U1 + latest uniFi controller) following this guide ; in both cases installation went without a glitch.
Let me know if you can access the link; if not I will send you a PDF printout.
Massimo
-RYknow
Massimo
I'm not able to access the link, just loads a blank page. I'll PM you my email address.
-RYknow
Battlebot32
I was able to get Unifi working by starting with a fresh jail and following part of Huib's instructions:
pkg update
pkg upgrade
portsnap extract
Then finishing with instructions posted by Matt on his website https://wiki.mattrude.com/FreeNAS/Unifi_Controller_Install
With the following code:
pkg install -y openjdk8
echo "fdesc   /dev/fd		 fdescfs		 rw	  0	   0" > /etc/fstab
echo "proc	/proc		   procfs		  rw	  0	   0" >> /etc/fstab
pkg install -y mongodb
echo 'mongod_enable="YES"' >> /etc/rc.conf
cd /usr/ports/net-mgmt/unifi5/
make install clean
echo 'unifi_enable="YES"' >> /etc/rc.conf
service unifi start
I waited a few minutes before logging into the GUI and was able to do the typical setup successfully.
When I followed just Matt's instructions or Huib's instructions separately I was not able to get Unifi working. The above combined method was the only way I was able to get it to work.
Sorry the post isn't cleaner. First time posting..
-RYknow
No worries! Thanks for the response! Another user had shot me an email with some instructions in a PDF. I've put off working too hard to get this running cause I bought a new switch and plan to change my IP scheme and everything once installed. Sadly I didn't measure my current wall mounted rack, and my new ubiquiti switch doesn't fit... :mad:
Anyway, a new rack is on the way and once it's here and my switch is installed, I'll be changing my IP scheme and be back to getting unifi running on freenas.
Thanks again everyone for your help! This is a great community and really appreciate everyones support!
-RYknow
KevDog
These lines if you put them in the /etc/fstab of a jail are not going to work:
These lines need to be mounted from the host FreeNAS installation. There was a post lurking about how to do this somewhere in the forums, but I can't find it. If I recall, it was dealing with installing bash inside a jail, since bash has a similar requirement.
-RYknow
Good to know. I imagine I could just ssh into my freenas box and edit the fstab file?
-RYknow
KevDog
No -- the file system for all the jails need to be mounted when the main system boots. I'll look around and see if I can find the post that describes how to do this -- its a setting you add to the main GUI freenas. I believe you add a line to the Tasks->Init/Shutdown scripts section. --- Let me look things up before I start spouting false information!!!
KevDog
Ok for followup --- The reference I was using to answer the question regarding fdesc was https://www.reddit.com/r/freenas/comments/2s0zgu/installing_bash_in_a_jail/
Within this thread the last comment stated
"in FreeNAS 9.3 you can specify a startup command. you can just run just the mount command then"
The statement is in general to running the mount command similar to the following -- this is being run within the base FreeNAS setup -- not the jail:
mount -t fdescfs null /mnt/tank/jails/bash_jail/dev/fd
I've also however found reference to a number of patches for the fdesc. I've looked in all my freebsd jails -- all of mine are under /mnt/tank/jails -- (your location might be different) -- and with the /dev directory there is always a fd mountpoint even when I didn't add it. I wondering if others could confirm this in there install. Some thread mentioned running the program screenfetch as a check since this utility calls the fd mountpoint. I installed screenfetch within one of my jails without using the mount command and it seemed to run OK.
So this entire requirement needed by bash for process substitution might be a non-point within by FreeBSD 9.10 installation It seems I already have a /dev/fd within all of my jails. Can others confirm this finding as well?
:(:confused::rolleyes:o_O
