Installing Ubiquiti UniFi Controller in a jail
gt2416
Member
You can make a simple sh script to update automatically
nano unifi5.sh
Paste this in there
pkg upgrade -y
service unifi restart
Make it executable:
chmod +x unifi5.sh
Add it to your crontab to run every week
crontab -e
Paste this line in
0 0 * * 0 sh /root/unifi5.sh
Jailer
Not strong, but bad
Because you're on the quarterly package repository by default. You need to do a pkg override to be on the latest repository.
przemor
Newbie
How to upgrade unifi controller from v5 to 6?
cd /usr/ports/net-mgmt/unifi5
service unifi stop
make uninstall
then install v6
will my data (logs, configs) stay in the new version?
colmconn
Member
service unifi stop
make uninstall
then install v6
Yes, everything stays the same. You should make a snapshot of your jail before you upgrade so you can roll back easily if the upgrade doesn't’ go smoothly.
msbxa
Member
and don’t forget unifi config backup first
