Part | Model | Amount | Power | Total Power |
Motherboard | X10SDV-F | 1 | 25W (est.) | 25 (est.) |
CPU | Xeon D-1541 | 1 | 45W | 45W |
RAM | Samsung M393A4K40BB0-CPB | 4 | 6W (est.) | 24W (est.) |
CPU Fan | Noctua NF-A6x25 PWM | 1 | 1.1W (max and typical power are inverted in the specs page) | 1.1W |
HDDs Fan | Noctua NF-A12x15 PWM | 1 | 1.6W | 1.6W |
SSD | Samsung 860 EVO 250GB (still considering) | 1 | 3W | 3W |
HDDs | Ironwolf Pro 4TB or 8TB (still considering) | 5 | 10W using 8TB drives (ST8000NE001) | 50W |
NIC | SPF+ dual port (unsure) | 1 | 10W (est.) | 10W (est.) |
| | | AVERAGE POWER WILL BE LOWER | 160W |
The 60mm fan has a 0.1A max current draw and the 120mm has 0.13A while the drives have a typical startup current value of 2A each: this means you need a PSU that's able to handle at least 12A (only for those parts) in the 12V rail.
Now, since we read the
PSU sizing guide, we know that each drive may require up to 35W of power during spinup: that's an additional 125W we have to consider: 160W + 125W = 285W.
Since we want to do things properly we take our number and multiply that for 1.25 in order to consider derating, which gives us a 322.5W: since we need SFX, we take 450W and make sure that your average power won't be under the 20% line of that power, which is 450W * 0.20 = 90W.
160W on a 450W PSU is roughly 35% of the total power draw.
Going with a 350W would be better from an efficency point but I doubt you will be able to find a good SFX one, plus you won't have much room for growth; anyway, it would bring the average power draw to a 46% which is better.
Considering the 450W, with ther corsair 80+ palatinum we saw before you would reach an efficency between 91% and 93%; with the seasonic 80+ gold you would be between 87% and 93%.
I eyeballed such values from their graphs, they aren't accurate.
Oh I thought the implication I could only hook up 4 SATA cables to the PSU, how many can I plug in then and how do I find this out? (sorry - new to even thinking about hardware - I have no idea how power supplies work).
You have to do the math looking at the rails of the PSU, generally your limits are at daisy chaining.
EDIT: given your loads, don't buy anything greater than a 650W: 750W*0.2 = 150W which is extremely close, if not above, your average power draw.
Generally you want to stay between the 40%-80% in order to get the maximum efficency from your PSU.
