isn't the [6pin to 3x 4pin molex] cable that the SF600 i have comes with basically one cable split into three? not two separate cables.
It's a single cable, yes, but it can (should since I don't remember the specs) withstand the full load of a few molex plugs; the overly safe move would indeed be to use two of such cables.
What is the problem with how the power is delivered through a splitter adapter like the one i was looking at? I'm not trying to necessarily poke holes - I just want to understand as much as I can.
The risk is the board needing more power than what a single molex plug (or the adapter's cables) can withstand: if I have 2 plugs and I connect both to one, there is a choke point... which can result in lower than required power being delivered or higher than (single plug) specs power being delivered. Plus, all the issues of bad splitter build quality (cables not able to withstand the power, bad crimps, etc).
yeah I can see that - although using two extenders like you suggest also has the same issue.
Yup, that's a compromise if you need the extra leeway (ie for space constraints)... not having a splitter lowers the chance of going overloading the single plug or similar issues.
I haven't done the math, don't have time. You could look for the numbers and see if you can use a single splitter, a single cable, or need different solutions. This thread is too old for me to remember, and I don't have much time to help you. Do your homework, or wait for seomeone else.
