a few weeks back we switched the sickrage repo we were pulling from. I think in some cases people had to edit files in /var/db/sickrage for the switch to work properly. this isn't freenas specific, I bet if you ask on the new sickrage github they could help track down what you need to do.
Josh,
As I mentioned before I have updates I can do for Sabnzbd, CouchPotato, Plex, and Sickrage. Is it ok to do those using the "Update" button on these or is it best to upload the pbi file directly into the jail to do the upgrade. Does this matter? Is one way better than the other? What I don't want to do is mess up anything else that I followed in your video because it has worked so well for me. I will search on github/sickbeard and if I don't find anything I will post a new topic. I will give my solution here as well to help out others that may have had the same problem.
