Bif
- Jul 26, 2016
Hi All
I’m a freeNAS new user and I love it. I installed it last week being a linux, scripting noob and now have it all set up with Couch Potato, Sickrage SABnzdb and headphones. The installation and configuration was fairly pain less although I had to scrub everything and start from scratch a few times. I got things working and CP/SR are downloading via SAB from my Usenet servers thanks to jruehlig’s tutorial and blog. My setup is as follows
+--[SABnzdb Jail]
As there is now no plugin jail template I Installed the SABNZDB plugin first then installed the other jails within that particular jail.
I installed exactly as Josh said without adding transmission as I don’t want to use torrents so I skipped all the install and config with regard to transmission.
The problem I’m having is with the scripts running after downloads are complete. The logs say:
[ERROR]::MAIN: A problem was reported in the /usr/local/share/nzbToMedia/nzbToSickBeard.py script.
then the error # ‘404 not found’. So the post processing stops.
I’ve spend 2 days trying to figure it out by trawling through the forums and have narrowed it down to a possible problem in the ‘autoProcessMedia.cfg’ file in that 'webroot variable could be problematic:
webroot = /sickrage
which it was initially, so after researching I changed two settings in the config file:
web_root =
fork = sickrage
as I read in another post this solved a similar problem, but I still get the same error once the post processing starts.
I know these problems are posted all the time to apologies for another one, but can anyone help?
Thank you!
+--[SABnzdb Jail]
----+[CouchPotato jail]
----+[SickRage jail]
----+[HeadPhones jail]
----+[Sickbeard jail] (OFF)
webroot = /sickrage
web_root =
fork = sickrage
Thank you!
