Suddenly very slow write speeds
Shoop83
Hi Folks
Haven't been able to find another thread discussing this exact problem.
Came back from vacation and moved some files from my Windows PC to my TrueNAS storage and the best it would give me is 355 kb/s.
This machine has been running for almost 5 years with transfer speeds I'm OK with. I updated to TrueNAS-13.0 a few months ago with no issues.
Some experimenting and I've found that there seems to be no issues copying or moving files from TrueNAS to my Windows PC. There seems to be no issues moving files around inside TrueNAS. If I try to copy a file in from TrueNAS to TrueNAS it nearly grinds to a halt.
Initially my storage utilization was at 85%, so I moved enough data off the TrueNAS to get it down to 74%. Rebooted it and waited over night. That did not seem to help anything.
RAM, CPU do not seem to be taxed during the file copy. Disc utilization doesn't seem maxed or anything.
I'm trying to figure out the right commands to run a dd test, and how to run an iperf test, but I am a slow learner and really don't want to mess anything up. I call this entire thing my house of cards. If I break it, it will take me a long time to figure out how to fix it.
That's a long way of asking, does anyone have a theory as to why my server would suddenly have horrendous write speeds? Are there any "do this first" tests I should run that might illuminate a problem?
Thank you all.
root@freenas[~]# zpool status
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0B in 00:00:14 with 0 errors on Tue Mar 21 03:45:14 2023
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
ada4p2 ONLINE 0 0 0
errors: No known data errors
pool: tank
state: ONLINE
scan: scrub repaired 0B in 12:01:37 with 0 errors on Wed Mar 22 12:01:37 2023
tank ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/4f64359d-1206-11e9-a206-ac1f6b60c826 ONLINE 0 0 0
gptid/50f5c733-1206-11e9-a206-ac1f6b60c826 ONLINE 0 0 0
gptid/52bd6456-1206-11e9-a206-ac1f6b60c826 ONLINE 0 0 0
gptid/544a2e08-1206-11e9-a206-ac1f6b60c826 ONLINE 0 0 0
root@freenas[~]#
Samuel Tai
Your pool is too fragmented.
Shoop83
Thanks for responding!
root@freenas[~]# zpool get fragmentation
NAME PROPERTY VALUE SOURCE
freenas-boot fragmentation - -
tank fragmentation 16% -
It looks like the primary remedies for a too fragmented pool are...
-add more drives in a second vdev to expand the pool and increase total storage, thus increasing free space for writing
-move everything out of the pool and back into the pool, thus reducing overall fragmentation
-something else?
Thank you.
Dice
I don't believe 16% fragmentation should grind the pool to virtually a standstill.
What could behave similarly is when a drive is significantly slower than others.
Ie, it might be letting go...
What's the SMART status on the drives? smartctl -a /dev/adaX
Solnetarraytest is something posted here on the forums that help speed test drives on a live pool.
Samuel Tai
Well, OP also said his pool was at 85% full, but he got it to 74% full. His pool's free space is too fragmented.
There's also backing up the pool, destroying it, recreating it, and then restoring the contents from backup.
Dice
Shoop83
Smart status on the drives:
Thank you for looking at this.
Dice
Mart status on the drives:
Nothing screams broken drives from that.
Old, but not necessarily broken.
67k power on hours!
Also, peculiar how the age timer somehow resetted here?
  1. SMART Self-test log structure revision number 1
  2. Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
  3. # 1 Short offline Completed without error 00% 1666 -
  4. # 2 Extended offline Completed without error 00% 1512 -
  5. # 3 Short offline Completed without error 00% 1331 -
  6. # 4 Short offline Completed without error 00% 995 -
  7. # 5 Extended offline Completed without error 00% 841 -
  8. # 6 Short offline Completed without error 00% 659 -
  9. # 7 Short offline Completed without error 00% 250 -
  10. # 8 Extended offline Completed without error 00% 98 -
  11. # 9 Short offline Completed without error 00% 65450 -
  12. #10 Short offline Completed without error 00% 65043 -
jgreco
Resident Grinch
The number doesn't represent fragmentation, it represents the difficulty the system is having finding free space -- it's almost a worthless number. And yes, high levels of fragmentation especially on a pool that has previously been nearly filled may cause huge amounts of I/O that bring the pool to a crawl.
Davvo
This might be useful in reducing your fragmentation if you don't want to restore from backup.
arc_summary output could be interesting.
Shoop83
arc_summary output here:
Thanks for looking at this!
I'll read through that other thread when I've got some time.
Shoop83
67k power on hours!
Yeah, old. Been basically constantly online since 2018.
Couldn't even begin to tell you why the age timer might have reset. Zero clue.
Shoop83
It's looking like excessive fragmentation is the likely culprit.
I have a SAS expansion card, and 4 new hard drives (identical to the existing ones) and a plan to expand my pool with a second vdev.
When I find the time to do that, seems like it might be best to just destroy the pool and create a new double size pool and then restore from backup. Is there a significantly better way to do this?
Thanks for looking at this.
Samuel Tai
Could be simple overflow. Looks like the max value is probably 65535.
Davvo
Your ARC values look normal at a first glance.
See @Davvo's post on:
Simple bash script to rebalance pool data between all mirrors when adding vdevs to a pool:
Shoop83
Very cool. Hadn't read that post yet. That looks a lot nicer than taxing my backup system.
Dice
In retrospect I can see how it is far more important to know the 'history of utilization' rather than current fragmentation numbers.
I got some hand's on experience on that department too.
Probably should've paid better attention to OP, had I read those parts more carefully, other clues would've emerged.
Interesting note on the fragmentation number. I can see what it <does>, also I can see how it would be less ambiguous if it was labeled differently.
What is a good definitive indicator of fragmentation being an issue?
Davvo
I would think slow write speeds and possibly (though harder to notice thanks to ARC) slower reads too if we talk about extreme situations.
Anyway, imho keeping that number low on spinners can't be a bad thing.
I wouldn't guarantee fragmentation being the issue here though.
If defrag doesn't solve the issue, please post the output of jgreco's sonlnet array.
