Good day all and thanks in advance for any support.
I am in the process of building my first NAS with TrueNAS core. The computer is as follows:
- I5-7400 in an asus k31cd-k motherboard (only has 1 pci slot – to be used for SAS controller in the future)
- 16GB ram (max the MB supports)
I installed trueNas on a 250GB sata ssd and connected a single 500GB HDD to ‘play around and make the mistakes’ before setting it up ready for prime time . I managed to get the NAS, plex server, nextcloud working and even can access via my own domain with port forwarding on the router, etc… Shares are SMB since I have mostly windows PCs (however there are android, iPhone, samsungTV, and an iMAC on the network also)
My main question is on the target configuration of the pool / vdev / disks…
Before I get there – here is the final vision of the NAS:
- Same MB/RAM
- LSI 9210 SAS controller (IT mode) with 8x4TB SAS HDDs
- (maybe): dual 250GB sata SSD as boot (only have 1 SSD today)
- (maybe) 2x2TB sata HDDs (depends on the advice below) (because I have the drives sitting around and I have room in the case)
- Run Plex server for movies and photos, NextCloud, maybe a backup application for PCs and maybe android/iPhone…
NAS purpose:
- Have a storage space for important files and photos (2TB is enough) that should be as redundant as possible.
- Have a large storage space for the media and streaming (I was thinking RAIDz1 if I understand it…) I want to utilize the disk space as much as possible. I have 8x4TB SAS drives and one cold spare if it makes any difference)
Questions:
1) Looking for input on the pool configuration, best way to setup the boot disk(s), important storage disks, regular storage…
2) Input on if I can add the disks and ‘fix’ the current configuration or if it would be best to blow it all away, install all the h/w, then reinstall fresh (I think I know the answer).
3) Related to the above – how do I mirror / protect the OS boot SSD? – is this something that is done after I install the trueNAS OS or before? Can it be done anytime?
4) Regarding apps and jails – should these have their own ‘disk or pool’ or part of my ‘big’ dataset ?
5) Any other ideas or considerations (especially regarding remote access – e.g. reverse proxy ideas, general security, etc…)
To throw into the mix – my ‘main’ PC is a xeon 2698v3 (16 core 32 threads) with 128GB RAM. Lots of PCI slots, 1TB NVME and a few 2TB HDDs. Its running win10 (I know I cant get the machine above 8% CPU utilization with what I am doing today ). The plan for the machine is for network virtualization (VMWare/VBox/GNS3 stuff – but these are hobbies and the machine is not running these workloads all the time or even often). This machine has other challenges (like the Quadro video card is a beast in terms of size so putting 8 new drives will be a challenge, current case is not conducive to cooling/case fans) (but I like my 4 monitors..) – power is another concern – it has an old 600W PS – the other machine was just upgraded to a new 600W (single rail) but the other PC uses integrated GPU much less hungry CPU. (I could swap.)
TrueNAS gurus – help me sort it all out open to any ideas.
Cheers,
Steve
Thanks!
- Same MB/RAM
NAS purpose:
Questions:
Cheers,
Steve
Thanks!
