Fleshmauler
- Jan 26, 2022
**EDIT** SOLVED IN TrueNAS-SCALE-22.12.4.2
I've noticed something a touch odd where the GUI for reporting disk temps never seems to update the temps for my HDDs until I reboot the system; and only then it'll set a temp & never change it until the next reboot. My NVMe drives seems to report real-time, and so does everything else.
To make it more confusing I have HDDs from both WesternDigital and Seagate; both experience the same oddity so I'm fairly certain it'd have something to do with TrueNas.
^^Please note that sda is a Seagate drive and sdb is WesternDigital... notice how temps are 100% static for weeks on end. This is over the summer with no AC in the room and with scrubs, smart tests, heatwaves, etc. It shouldn't be static. I had days where it was 40*c outside, and I had nights where it was 12*c at night during this period.
^^From the above example GUI is showing 47*c and 46*c for sda and sdb respectively, when in reality they are sitting 40*c and 38*c.
Full system details in signature.
This isn't a major issue, but does make me wonder if my email alerts would ever trigger & wondering if there is an easy fix or if I should submit a Jira ticket for this (or if one already exists).
Something to note is that my disks are connecting by mix of HBA and directly to the motherboard - all HDDs exhibit this oddity with the reporting GUI.
I also have no earthly idea when this started - for all I know I could have been experiencing this ever since I switched over to scale.
*I have also had at least 1 clean install with re-importing of settings during this 6 month period, so I'm uncertain if that'd be a viable solution.
*minor edits for typos & clarity
**Ticket created
Here is the GUI for the same two disks on an hour running graph, both are the highest temps during a heatwave & a scrub running from several weeks ago:
Here is the smartctl -a output for both for them respectively:
#smartctl -a -v 1,raw48:54 /dev/sda -v 7,raw48:54 -v 195,raw48:54 smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.107+truenas] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate IronWolf Device Model: ST8000VN004-3CP101 Serial Number: WWZ0T9G6 LU WWN Device Id: 5 000c50 0e5898af1 Firmware Version: SC60 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-4 (minor revision not indicated) SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sat Sep 30 14:13:41 2023 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 559) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 693) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x50bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 076 064 044 Pre-fail Always - 0 3 Spin_Up_Time 0x0003 091 091 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 23 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 084 060 045 Pre-fail Always - 0 9 Power_On_Hours 0x0032 092 092 000 Old_age Always - 7517 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 23 18 Head_Health 0x000b 100 100 050 Pre-fail Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 060 052 000 Old_age Always - 40 (Min/Max 36/48) 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 17 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 341 194 Temperature_Celsius 0x0022 040 048 000 Old_age Always - 40 (0 18 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 7486h+56m+33.775s 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 10814194360 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 1372284475009 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 7409 - # 2 Extended offline Completed without error 00% 7324 - # 3 Short offline Completed without error 00% 7241 - # 4 Short offline Completed without error 00% 7073 - # 5 Extended offline Completed without error 00% 6988 - # 6 Short offline Completed without error 00% 6906 - # 7 Short offline Completed without error 00% 6666 - # 8 Extended offline Completed without error 00% 6580 - # 9 Short offline Completed without error 00% 6498 - #10 Short offline Completed without error 00% 6330 - #11 Extended offline Completed without error 00% 6245 - #12 Short offline Completed without error 00% 6162 - #13 Short offline Completed without error 00% 5922 - #14 Extended offline Completed without error 00% 5836 - #15 Short offline Completed without error 00% 5754 - #16 Short offline Completed without error 00% 5586 - #17 Extended offline Completed without error 00% 5501 - #18 Short offline Completed without error 00% 5419 - #19 Short offline Completed without error 00% 5203 - #20 Extended offline Completed without error 00% 5117 - #21 Short offline Completed without error 00% 5034 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
# smartctl -a /dev/sdb smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.107+truenas] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: WDC WD80EFBX-68AZZN0 Serial Number: VRJY3JAK LU WWN Device Id: 5 000cca 0c2e96b02 Firmware Version: 85.00A85 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sat Sep 30 14:14:36 2023 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 87) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 907) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0004 127 127 054 Old_age Offline - 112 3 Spin_Up_Time 0x0007 169 169 024 Pre-fail Always - 513 (Average 447) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 48 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000a 100 100 067 Old_age Always - 0 8 Seek_Time_Performance 0x0004 128 128 020 Old_age Offline - 18 9 Power_On_Hours 0x0012 099 099 000 Old_age Always - 11775 10 Spin_Retry_Count 0x0012 100 100 060 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 48 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 525 193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 525 194 Temperature_Celsius 0x0002 171 171 000 Old_age Always - 38 (Min/Max 17/51) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 11668 - # 2 Extended offline Completed without error 00% 11586 - # 3 Short offline Completed without error 00% 11500 - # 4 Short offline Completed without error 00% 11332 - # 5 Extended offline Completed without error 00% 11250 - # 6 Short offline Completed without error 00% 11164 - # 7 Short offline Completed without error 00% 10924 - # 8 Extended offline Completed without error 00% 10842 - # 9 Short offline Completed without error 00% 10756 - #10 Short offline Completed without error 00% 10588 - #11 Extended offline Completed without error 00% 10506 - #12 Short offline Completed without error 00% 10420 - #13 Short offline Completed without error 00% 10180 - #14 Extended offline Completed without error 00% 10098 - #15 Short offline Completed without error 00% 10012 - #16 Short offline Completed without error 00% 9844 - #17 Extended offline Completed without error 00% 9763 - #18 Short offline Completed without error 00% 9677 - #19 Short offline Completed without error 00% 9461 - #20 Extended offline Completed without error 00% 9379 - #21 Short offline Completed without error 00% 9293 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
**Ticket created
