D
DeletedUser88470
Guest
Finally I have have my NAS up and running! :)
Now I am in the process of installing plex, and I figured that it would be of quite a benefit to ask the community here for help before going out of my mind.
I can see most posts prefer a manual install in a jail and not the plex plugin? Why, is not quite clear to me, but something updates being delayed?
I have tried to follow this tutorial: https://forums.freenas.org/index.ph...to-install-plex-in-a-freenas-11-0-jail.19412/
- I have created a jail, and this creates the first issue - since I am using Windows on all my pc's, I have selected a "Windows" Share Type on all of my datasets - should I also do this for the jail dataset, or should this be UNIX? Is using the Windows share type the general opinion when sharing mostly with windows pc's?
I selected UNIX for the jails (found a little info on this somewhere on the web) and continued, but I cannot get access to the jail in the final step through the web browser.
During the installation, when running the command: pkg install multimedia/plexmediaserver -y
I get the reply pkg: No packages available to install matching '-y' have been found in the repositories
I assume that this is not normal - should i delete the dataset and start over?
Is there another tutorial that I should follow instead?
Sorry for all the questions, but I am struggling a bit.
