Plexmediaserver not Running (check /var/run/plex/plex.pid)
SweetAndLow
Sweet'NASty
varcal
i reinsatall my plex
with this
root@plex: #pkg upgrade -y ; sleep 5 ; pkg install -y plexmediaserver_plexpass ; sysrc plexmediaserver_plexpass_enable="YES" ; service plexmediaserver_plexpass onestart ; service plexmediaserver_plexpass status
and now i get this
root@plex: # service plexmediaserver_plexpass restart
plexmediaserver_plexpass does not exist in /etc/rc.d or the local startup
directories (/usr/local/etc/rc.d), or is not executable
SweetAndLow
Sweet'NASty
that's because you installed nothing. You need to install plexmediaserver-plexpass. You need to learn to follow directions and just copy what I showed you.
after it's installed you can use pkg info plexmediaserver-plexpass to check the version.
varcal
i get the plex to work but i had to upgrade to 11.2 and use the plug-in
but i do have a new question in my jail i have it setup using DCHP and it works great but i want to use Static when i do that it will not update the movie poster in plex
how do i get static to work right
under ipv4 interface i have
re0
bridge0
epair0a
vnet0
SweetAndLow
Sweet'NASty
hahaha you are using a realtek nic. dude you just keep failing. Realtek nics do not really work with freenas and you will get poor performance if it even works.
To answer your question make sure you have nameservers and gateway setup.
SweetAndLow
Sweet'NASty
